Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 05-24-2016 | 09:35 AM
  #27616
eR1c's Avatar
It's JPY5600 so about $51.. but since these are all gifts, it's free to me.
Basically it's a pick your poison.
I do the same when I visit him from the US.
-I need to find me a friend from Japan.
Which version of the chassis do you have and which version of the motor mount do you have?
I am betting he has the Tamiya M05VII chassis w/ the Tamiya M05 motor mount OR a washer or something is missing from the steering which would prevent that clearance. ...I'll have to look at my setup when I get home.
eR1c is offline
Old 05-24-2016 | 01:01 PM
  #27617
iluvmud's Avatar
FFFFFFFFFFFFFFAAAAAAAAAAAAAAAAAQQQQQQQQQQQQQQQQQ
iluvmud is offline
Old 05-24-2016 | 04:23 PM
  #27618
iluvmud's Avatar
The motor plate is the wrong damn one
iluvmud is offline
Old 05-24-2016 | 06:03 PM
  #27619
Hey does anyone know where to find a 3s lipo battery that will fit the m05s battery compartment? I have a pair of 2s but looking to see if I can get a 3s. Apparently it's harder than finding a palm tree in Antarctica!
M05 newbie is offline
Old 05-24-2016 | 06:20 PM
  #27620
KA2AEV's Avatar
Why would you want to put a 3s in there?
KA2AEV is offline
Old 05-24-2016 | 06:22 PM
  #27621
The most BAM possible. I think it's a little bit too much but wanted to see if its possible. Might be better for more power.....but again....just thinking outside the box. I have a feeling it's gonna be a BIG challenge and is probably worth it to just go brushless.....just an idea.
Old 05-24-2016 | 06:57 PM
  #27622
gigaplex's Avatar
Did you upgrade to the V2 chassis yourself? I thought the V2 Pro kit came with the correct aluminium motor mount.
gigaplex is offline
Old 05-24-2016 | 07:18 PM
  #27623
tony gray's Avatar
If you find one, buy 4 sets of gears as well because you will shred them in about two minutes...just sayin....
tony gray is offline
Old 05-24-2016 | 08:46 PM
  #27624
Does any one know if the new M05 version 2 R uprights are the aluminum ones? It doesnt really say in the description if they are but I am assuming they probably are.
nsx2007 is offline
Old 05-24-2016 | 10:55 PM
  #27625
shmit 1's Avatar
They are plastic.
shmit 1 is offline
Old 05-25-2016 | 04:48 AM
  #27626
sakadachi's Avatar
I think you should get a 4WD m-chassis (or a TC) if you want to put down that much power. M05's only have moderate straight line grip and will take a long time to get to top speed while your tires freewheel and gears burn up inside making the drive probably not so fun.
imho these FWD cars are most fun driving spiritedly running mild to moderate power. 4WD m-chassis can handle a lot more power you can actually put down.
sakadachi is offline
Old 05-25-2016 | 07:32 AM
  #27627
(0000000000)'s Avatar
It's his prerogative. If somebody wants to connect a 3S LiPo to a 18 turn brush motor, in a mini, have at it. I personally would recommend against it.
In fact, I personally don't recommend any hop ups for a mini that is going to get kicked around in front of a driveway.
(0000000000) is offline
Old 05-25-2016 | 09:51 AM
  #27628
eR1c's Avatar
+1
eR1c is offline
Old 05-25-2016 | 09:13 PM
  #27629
iluvmud's Avatar
I did.... I bought the M05 used and since the chassis needed to be replaced might as well use the V2 one.... ebay never mentioned a V2 motor plate had to find it on Tamiya.com and once there i found it on ebay..... it's in queue to be ordered.
iluvmud is offline
Old 05-26-2016 | 09:45 AM
  #27630
I had a 7turn brushed motor in my m03 once with a heavy nimh pack . It was fast, but ate the gears in less than 20 runs.... 3S lipo is worse for your gears than my setup... Good luck with that.......
bertrandsv87 is offline
