Tamiya mini cooper
It's been a few years though...
http://www.cheapbatterypacks.com/pro...tick-Pack.aspx
R/C Tech Elite Member
I think we've had this conversation before, but why is it the local club insists on nimh batteries? There have been quite a few years to transition. Is someone influential in the community afraid or too cheap to switch? There is always an impact on racer, but spread it out over a year and it won't hurt a bit.
Of the pinions I've tried The Tamiya fluorine coated pinion is good, but it doesn't have enough meat around the set screw so it can strip in time. The Robinson is good, but my usual suppliers don't stock it and the shipping is more than the pinion from those that do.
Good one Bob! My Google Fu failed me on that one.
Location: Everett WA in the Summer Mesa AZ in the Winter
http://www.tqrcracing.com/shop/produ....asp?p_id=6108
Whether you go for cheap or expensive cells, a good charging/discharging/balancing/storage regime is essential to good performance and longevity.
Thanks for the Advice guys
Getting rid of my stock kit pinion.
And rebuilding my chassis with hex hardware!
@MonkeyRacing how did you know there would be one at great hobbies?
I am wise beyond my many, many...many years. It's a pretty common part anywhere minis are popular.
And I guessed.
And I guessed.
I recently picked up some pit shimizu tires for my mine. the treaded type. i got hard and med compound. im going to let my son run these on high grip carpet.
which end should i run the tires on. hard fronts/ med rears? or med front hard rear? its only going to be run on carpet 2 times, after that its outdoors on pave. just thinking ahead for asphalt since i know the carpet wont wear them out. im thinking hards front and the med rears since the fronts will take more of the punishment due to fwd and more front weight bias. btw tires on the rear are offset rims and fronts are standard rims. these are not glued up yet so not sure what to do. any help is greatly appreciated.
anybody? anybody run there on the minis? just a little help would be nice.
Sorry, but that's all the help I can muster. Sweep premounts seem to work pretty well on most surfaces. Atomics or Spices may be better on asphalt than the Sweeps, but availability is the problem with these tires.
thanks for the help. my son is only running the novice class so he isnt going to be very fast yet. ill be driving it outdoors in a month. but for now i tested the car with the hards in front and the the med up front. its much better with the med up front. so thats how ill run it for now.
Hi all,
Any idea what wheels these are? I'm after a set without tyres
Cheers!
Cheers!
@ boons.-any pics in regards to the wheels?
