Tamiya mini cooper
silly question...
which do you guys prefer:
a well-shimmed gear/stock diff with a little anti-wear grease; or
a ball diff tightened all the way up?
both diffs are close to spool-like feel, with a little slip
I've been running a tighten ball diff (ta03) but was messing around with one of my stock diffs for the rebuild of my M03 - and thought 'hmmm, maybe this might be better in the M05????' for the record, the M03 had a manta ray diff in it and has worked well - but noticed it wasn't as tight as the diff in my m05
so was wondering what some opinions are
It's not letting me upload pics, I'll try later. They are white chunky looking minilites
http://www.rctech.net/forum/attachme...1&d=1396187710
Hi all,
I am looking for a pair or set of Mercedes Benz SLK Rims/Wheels (M-02L), do PM me if u have any to let go.
Regards
Clarence
Regards
Clarence
And it's the end of an era... Guys you have one month to d/load the veritable treasure trove of knowledge off rc-mini.net. As after that (or nearabouts) the site will cease to be.
Realistically we've pretty much covered everything that we ever wanted to do and none of us really have any time to take it any further.
So, right mouse click and 'save as' on anything you want, because soon it'll be all gone....
Tony G rc-mini Imperial Grand Poobah.
p.s. the FB page will keep going, just to keep our hand in : )
Hey Guys,
I bought a set of premounts for TCS mini last friday and discover one of the tire has a dead spot. I wish they would have glued the inserts together. But all in all it was a fun day at TCS
I'm currently vacuuming up the entire site for future reference.
Thanks to you for all your efforts to educate the rest of us cave dwellers and for showing us you can do it on the cheap.
Nooooo.......my favorite mini site.
Maybe its an april fools day joke...one can only hope.
Thanks to all for the kind words, but it's time to move on!
rc-mini will still exist in Facebook form, and if we feel inclined there will still be stupidity every now and then.
Tim and I started this 15 Sept 2006 so it's been going quite a while now, and I think even we underestimated the impact that it's had. But....we havent really done anything new for about 2 years, there just isnt much going on. And to be honest we dont even race as much any more.
If people want to 'borrow' what we've done and use it elsewhere, thats ok with us.
As for someone else hosting the entire site, we'll pass. We either do it full on, or we're out.
rc-mini will live on, but just in a lesser way. We're proud knowing that we've made the rc world just a little less serious..
And for those who dont recall it, this was probably Tims finest hour - here
Oh and in late breaking news... rc-mini Tech Geek Tony P, has revealed this site...which will enable you to acccess all our juicy goodness even after we take it down apparently!
https://web.archive.org/web/20130902...mla/index.php?
Hey guys have been looking at the Killshot 21.5 B/L motors and am alittle confused
They have a Hi Revs motor and a High Torque Motor
Common sense tells me that I should be looking at the Hi Revs version
but that little voice in my head is saying something that I can't understand ( no dumb comments please!)
Whats your thoughts on the differences!
Mike
Mike
Mike
Mike
For the Killshot, go with the RPM version. They are competitive.
you could change the internal gears for the high speed set https://www.tqrcracing.com/shop/prod....asp?p_id=1591
im doing this for the summer season and i doubt ill run the tcs race locally since i will have non tamiya internals (unless i dont say squat and gear it so its even) i ran the car with a 25.5 (local scale spec rules) and it sucked bad. super slow. ive since changed to a 21.5 and its better. unfortunately my gear set wont arrive till saturday and i need them for this saturday.
If you're using an M03 you can always try the Sydney trick ... using standard tamiya internal gears, put a 23 or 24 tooth pinion on, but just hold it in with 1 motor screw - done up really tight. On the M03 you can check the mesh but on the M05 there is no way to check. But that would get you a bit more top end while you're waiting for your speed tuned gears to arrive.
