Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 09-29-2011, 04:07 PM
  #15856
Misiek's Avatar
I'm replacing my gear dif with ball dif and got another question....
In addition to TA03 diff, should I also get hard joint cup set (53217)?
Misiek is offline
Old 09-29-2011, 08:02 PM
  #15857
R/C Tech Elite Member
monkeyracing's Avatar
Does anyone know of a source for Xevo parts? I've got one on the way and having a source for spares would be handy. Especially want to keep my eyes open for upgrades like droop limiters and the suspension upgrades.
In addition to TA03 diff, should I also get Hard joint cub set (53217)?
Couldn't hurt, but not immediately necessary.
Jim
monkeyracing is offline
Old 09-29-2011, 08:05 PM
  #15858
Jim
Also you could run plastic "blades" to reduce wear.
nytryder is offline
Old 09-29-2011, 08:20 PM
  #15859
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Looking for a part number for the Tamiya front graphite m05 shock tower.
j.d.roost is offline
Old 09-29-2011, 08:23 PM
  #15860
Misiek's Avatar
Tamiya 54320
Misiek is offline
Old 09-29-2011, 08:38 PM
  #15861
Misiek's Avatar
[QUOTE=monkeyracing;9721667]Does anyone know of a source for Xevo parts? I've got one on the way and having a source for spares would be handy. Especially want to keep my eyes open for upgrades like droop limiters and the suspension upgrades.
I guess the real question is if the outdrives (53217) are better than the ones included with the TA03 diff
Misiek is offline
Old 09-29-2011, 08:42 PM
  #15862
tony gray's Avatar
Jim
You wont want to hear the phrase 'There is no source for Xevo parts now' then will you Jim.....
We've been trying for 6 months, and gave up.
tony gray is offline
Old 09-29-2011, 08:43 PM
  #15863
They are stronger, no question about it.
Now, about those Xevo bits...
Old 09-29-2011, 08:56 PM
  #15864
j.d.roost's Avatar
Tamiya 54320
ty
Old 09-29-2011, 10:03 PM
  #15865
Tamiya M-05 steering sweeper dimensions. Measured center to center on the fasteners:
37mm at the posts, where they connect to the chassis. 55mm at the ball ends.
Attachment 814141
Thanks !
I think this will be a big upgrade then for the Avante.
With the original steering sweeper I have alot of bumpsteering because the steering links are so short, but now I can use links that are almost 10mm longer.
Thanks again sir
ridgeracer is offline
Old 09-29-2011, 10:17 PM
  #15866
They're out of business, then? Guess I'd better brush up on my fabrication skills, because I crash. Lots. I haven't had to carve up any carbon fiber for a few years now. The last hunk of carbon I had hanging around was a tailpiece from a Porsche Carrera GT. Those were some damned expensive mini parts.
Tony, do you have a scan of the Xevo Chariot manual you could send my way?
Jim
Old 09-29-2011, 10:25 PM
  #15867
cannon's Avatar
Trader Rating: 35 (100%+)
Jim
The owner of Xevo was not very keen on selling spare parts originally .... was more along the lines "just buy a new kit"
I haven't spoken to him since late last year when he found out the Xevo would not be allowed at TITC again , Maybe he just gave up
cannon is offline
Old 09-29-2011, 10:35 PM
  #15868
spring71's Avatar
Smile
Hello Mini racers,
We have indoor carpet rc track in Chino, CA.
2011 1st Annual Sweep Challenge USA will be held on October 30th at TQ RC RACING.
All 1st, 2nd and 3rd winner will get the Sweep Custom Designed Setup Board as a race award, and cool raffle prizes will be ready for All racers.
Pre-Signups are available, Please click Here.
13871 Oaks Ave
Chino, CA 91710
Tel: 909-627-2800
Web: www.tqrcracing.com
Email: [email protected]
Here is the class rule for Sweep Challenge.
No-Timing Class: Must use Roar Approved Sportsman ESC, Click Here
There will be special discount for the Handout tires on the race day.
Rookie, Sportsman, Expert Sedan
ESC: No-Timing ESC
Motor: 17.5
Battery: 2s Lipo
Tire: Sweep QTS32 Real Blue Premount spec tire, handout tire. Click Here
Modified Sedan
ESC: Open ESC
Motor: Open Motor
Battery: 2s Lipo
Mini 4WD
ESC: No-Timing ESC
Motor: Silver Can
Battery: 2s Lipo
Body: Scale body Only, no racing body allowed.
Tires: Sweep MN40 Premount spec tire, handout tire Click Here
Gearing: Open
Mini 2WD
ESC: No-Timing ESC
Motor: Silver Can
Battery: 2s Lipo
Tires: Sweep MN40 Premount, handout tire Click Here
Chassis: Mini Fwd or Rwd chassis only. No conversion from 4WD to 2WD.
Fixed Gearing for Mini 2WD:
HPI Switch: Pinion 27T / Spur 62T
Tamiya Mini, X-Evo: Pinion 20T, Fast Gear Set is not allowed.
ABC Grid: Pinion 31 / Spur 50/30 (Option #25756 Click Here)
ABC Goose: Pinion 29T / Spur 84T
1/12 17.5
ESC: No-Timing ESC
Motor: 17.5
Battery: 1s Lipo
Body / Tire: Open Foam
1/12 Mod
ESC: Open ESC
Motor: Open Motor
Battery: 1s Lipo
Thanks.
spring71 is offline
Old 09-29-2011, 10:41 PM
  #15869
tony gray's Avatar
Jim
I'm sure something can be found....although its next to useless anyway. I built mine using the pictures of Tims original car on our site!
Leave it with me...
Old 09-29-2011, 10:42 PM
  #15870
Did they ban it because of an injection molded only rule? Can't imagine why they would otherwise. Still, it's a bit odd, especially considering the ridiculous amount of modification they allow anyway.
Looks like I've got an orphan on the way.
Jim
