Monster Stock Getting Very HOT!!!
I cant see why my monster stock pro is getting soo hot. Its not overgeared as its only running at a ratio of 6.5.
Can anyone help, thanks
6.5?!?!? Man, I gear my monsters at 8.0. They are all rpm, no torque. Try it 8.0, you'll be surprised
also be progressive on teh throttle out of turns, this will help to minimise the current through the motor, and keep it cooler, and keep the batts voltage higher for longer
Depends on the track, weather and the efficiency of a car's drivetrain.
Down here in down under we gear our Monsters at around 6.1 because our tracks are very big.
I run mine at 7.8 for a fairly large and sweeping track. 6.5 sounds way overgeared.
Originally posted by defMondo
Try 5.6 itchy.
Try 5.6 itchy.
how bout a track with alot of "u"turns and some 90 degree turns about a 20m straight what would you guyz gear it at?
That sounds like a tight track, try 7 to 7.5, that's what I gear at when I race at tight track.
As mentioned above, if you can be very smooth on the throttle and even on hair pins be able to drive through them without lots of stop and go style throttle control then you can get away with gearing up, but you have to be smooth.
Tony
Tony
