Old 06-13-2003, 05:06 PM   #1
Send a message via AIM to Johnnytc3
Default KO MARS R problem
Hello,
i just installed a servo in my new car, and when i gas it it goes in the wrong direction. Does the KO MARS R have a throttle reverse function, i cant seem to find it, but i can find the steering reverse.
johnny
Johnnytc3 is offline   Reply With Quote
Old 06-13-2003, 06:19 PM   #2
TRF-Powered's Avatar
are you running an electric car or gas car? if it's electric.. it's more then likely that you have hooked up your battery to the motor backwards...
if it is a gas car... just reverse function in your Mars to reverse your throttle servo... look into the manual to see how to adjust it..
TRF-Powered is offline   Reply With Quote
Old 06-13-2003, 06:21 PM   #3
its a gas car, i dont have a manual for it, so it does have a throttle reverse function?
Old 06-13-2003, 06:31 PM   #4
TFR
TFR's Avatar
Yes, when you see the steering reverse part, hit the 'select' button and it will go into 'th rev' or 'th nor'...
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 06-13-2003, 08:28 PM   #5
Thanks a BILLION plus some
JOhnny
Old 06-14-2003, 12:32 PM   #6
Johnny follow these directions--
1. set your radio to the model you need to work on.
2. turn your radio off
3. hold down the ballance/down and key.a/up keys
4. while holding the keys turn the radio on
5. the radio should now say "system mode"
6. use the up and down key to get to the screen theat says "REVERSE".
7. use the M.sel/select button to switch between steering(ST) or throtle(TH)
8. use the + or - key to select between normal(NOR) or reverse(REVE)
9. once you servo reverse function is corrected hit the direct key to get back to the main menu.
In the system mode you can change all of the settings you wouldn't wanna accidentally bump during a race....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-18-2003, 09:51 PM   #7
Thanks impact player,
would you know how to reset the radio to factory settings?
thanks
johnny
Old 06-19-2003, 09:27 AM   #8
Default Resetting to factory defaults1.
You can only reset one model at a time--
1. enter system mode
2. use the up/down keys until the screen reads "1-5 Step Recall"
3. press the select key until the screen reads "Memory Reset"
4. hit the + key , your screen should read "Memory Complete"
Spektrum Module for KO EX10/Mars/ Mars R Crawler R/C Items: For Sale/Trade 4 04-20-2008 05:19 PM
KO EX10/Mars S/Mars R Spectrum Module & Receiver Crawler R/C Items: For Sale/Trade 7 01-26-2008 08:08 AM
KO MARS AND MARS R 40MHZ MODULE(RF103F) WITH RECEIVER KR-301F AND CRYSTAL SET (RARE) Sigearhead R/C Items: For Sale/Trade 2 05-03-2007 06:19 PM
spektrum pro system for Ex-1, Mars, Mars R, Ko propo willabong Australia For Sale/Trade 1 03-18-2007 09:15 PM
KO propo EX-1 Mars! Problem with servo tt01-demon Australian Racing 8 03-15-2007 07:18 AM
