Like Tree6Likes
Tamiya Ta06
Old 04-09-2013, 03:25 AM
  #2206
kentech's Avatar
Some translated product info: http://kentech.blogs.se/
84352 TA06 MS Chassis Kit
- 2.5mm thick and rigid main frame made ​​of carbon, in the upper deck 2.5mm thick, which is set via the front and rear aluminum Steph Nadu. Double deck specification with enhanced accuracy.
- In response to a request from the user to pursue the left-right balance of RC mechanism, steering aluminum and carbon mechanical steering linkage included deck dedicated to enabling the right layout of the servo
- Aluminum turnbuckle, TRF Special Damper, double cardan shaft (2), Universal clip-on shaft (2), Front Direct Coupling Equipped with a 39T pulley.
kentech is offline
Old 04-09-2013, 06:22 AM
  #2207
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by sosidge
Tamiyablog are saying that there will be a carbon chassis version of the TA06 at Shizuoka (#84352). Might explain why I've seen a few heavily discounted TA06's online in the last couple of weeks.
probably a conversion or the r version that eventually will come out.
izzyracer is offline
Old 04-16-2013, 01:39 PM
  #2208
kentech's Avatar
TA06 MS
kentech is offline
Old 04-17-2013, 07:20 PM
  #2209
bhambrent's Avatar
Could not get my Thunder Power motor to work in this car. What motor's do fit?
Thanks,
bhambrent is offline
Old 04-17-2013, 07:50 PM
  #2210
BadPanda818's Avatar
Trader Rating: 19 (100%+)
Thanks,
any motors with the tabs close the the bottom of the motor like Orion vst and tekin redline first gen. I've also heard about bending the tabs itself to fit the compartment. You do run the risk of breaking the tab if not properly executed.
BadPanda818 is offline
Old 04-17-2013, 09:12 PM
  #2211
izzyracer's Avatar
Reedy sonic
Old 04-17-2013, 10:31 PM
  #2212
Just a quick question. My 06 owns when we use to race with 17.5 with an 85 spur 55 pinion. When the track decided to go to 10.5, my car didn't have the same punch and responsiveness that my car had with the 17.5. No chance was done to the chassis except for the motor. I used a 95 spur due to the 88 spur being too small and can't mesh with the pinion properly. Is there something I'm missing ? I understand the torque difference between the motors. It's just too big of a difference if it's only the torque difference. If it's necessary, motor temps are 130 on 17.5 and 125 on 10.5 on average and I use 64 pitch. Thanks for helping
Old 04-18-2013, 07:23 PM
  #2213
Any takers?
Old 04-21-2013, 05:44 AM
  #2214
kwkride's Avatar
Any takers?
For TC classes we only run USVTA and USGT so nothing faster than a 21.5
I'm guessing if the only thing that you changed was the motor, then you may need to make another gearing change. Is there a reason that you can't run the same gears that you had in with the 17.5?
kwkride is offline
Old 04-21-2013, 08:49 AM
  #2215
The 88 spur isn't big enough diameter wise to mesh with any of my pinion ie 28-33 pinion
Old 04-21-2013, 09:02 AM
  #2216
nolo148's Avatar
Then get a bigger spur or get a bigger pinion
nolo148 is offline
Old 04-21-2013, 09:15 AM
  #2217
I did. I used a 95 spur. My question is that I didn't have the same punch and responsiveness when I used a 85 spur.
Old 04-21-2013, 09:25 AM
  #2218
nolo148's Avatar
Maybe go for a bigger pinion since u lowered the teeth on the spur by 10 so maybe go up in pinion by 10 teeth
nolo148 is offline
Old 04-21-2013, 09:55 AM
  #2219
terrible advice. BadPanda818 increase his spur by 11.7% ((95-85/85)x100) therefore he needs to increase his pinion by 11.7%, NOT 10 teeth, to maintain the same ratio he had before. Ex, if he had 33t pinion before, he needs a 36/37t pinion now.
d300guy is offline
Old 04-21-2013, 10:41 AM
  #2220
nolo148's Avatar
I meant going up 10t from his 28t, oopps guess i wasnt clear enough but going up 10t from 28t is 38t so its not that far off. Badpanda818, what are the other people at your track running in terms of fdr? I would follow them
nolo148 is offline
