Like Tree1Likes
Closed Thread
Old 12-31-2009, 03:10 PM   #7381
BadSign's Avatar
Trader Rating: 15 (100%+)
Originally Posted by robk View Post
3.6
What is a standard FDR for your track with the 21.5?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline
Old 12-31-2009, 03:18 PM   #7382
Scottrik's Avatar
Trader Rating: 245 (100%+)
Originally Posted by CSeils View Post
I guess i have to get a new car or quit. I can't get that kind of ratio out of any of my TC cars without cutting something. Way to tall if you ask me. No turbo and raising the FDR would have been less expensive.
Any suggestions on what the car of the month is?
I'm just saying that raising the FDR would have been less expensive for everyone. Newbies would still need the equipment but the rest of us would only need a few gears or so. Now we all need new motors and a bunch of gears.
I'm running a Tamiya car. I would need a 78 spur and a 45 pinion (48 pitch) just to get to 3.7 (need a 44 but no one makes it). Large pinions are hard to find these days. I'm not sure that would even fit without milling something down.
Just my .02
Hmm...a couple questions.
First, what other TC cars do you run? You indicated "any of my TC cars" in your initial post. Or are they ALL Tamiya. "My TC car" would imply one, "Either of my" would imply two, "any of my TC cars" would certainly seem to imply 3 or more.
Second, your first post quite plainly says "can't" while your subsequent responses seem to be vacilating on that to where now it seems it will merely be, perhaps, inconvenient...perhaps requiring you to purchase a gear or two?
Third, first they won't fit, then the concern seems to be that pinion and spur combo might be too small and not reach each other. How long have you been involved in RC? If you're to the happy condition that the gears won't reach then you (should, anyway) know for fact that a combination can then be had that will give the desired fdr AND reach together to mesh.
Kinda sounds like another red-herring argument was thrown into the mix perhaps? Like I said, the most gearing-limited car I'm familiar with can do 3.5 with relative ease. Took me about 30 seconds with a Dremel and a grinding bit.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 12-31-2009, 03:28 PM   #7383
Scottrik's Avatar
Originally Posted by rcracenut View Post
Man in car. Come on. These things not matter how light they try to make them will effect the handling, whch will effect the learning curve of the new racer. Besides it looks lame.
Can you back that up as fact? Puh-leeze.
I'll have a full interior tray in my car once it arrives and I get it painted up and I'll bet you pretty much whatever you care to lose that I will turn pretty much identical lap times with and without the interior in my car. It will be a non-issue, handling-wise.
If your driving skills are SO advanced that adding MAYBE 7 grams of weight to your car can be measured on the clock then I should be seeing your name at the top of the A-main list at every major race everywhere and your face on every add for every product worth buying. You'd be like Masami squared. I'd doubt most people could measure the change with a full ounce, and we're talking a fraction of that.
And "looks lame"? You're certainly welcome to your opinion, I guess, but you'll have to explain to me how a nicely executed driver / interior tray possibly detracts from how any car looks? I don't get that reasoning at all. What looks "lame" is looking through the window of a nicely painted car and seeing a rat's nest of wires, drive train components and chassis stiffeners.
Scottrik is offline
Old 12-31-2009, 03:59 PM   #7384
robk's Avatar
Trader Rating: 22 (100%+)
+ YouTube Video
robk is offline
Old 12-31-2009, 04:00 PM   #7385
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:03 PM   #7386
Racer X79's Avatar
Trader Rating: 30 (100%+)
Wow, alot of reading to do after missing the big rule change....at least we know there's no shortage of interest in the class .
Great job on the rules Rob, everything should work out great and I way look forward to running the 25.5 motor....especially with no FDR. That will bring a qualifying vs. main set up back into play like the 27t/4 cell days.
On a side note, we've been running the 5.2 fdr/no timing rule at Trackside the last couple weeks. That alone has tightened up the racing quite a bit and the Novak USORC race next week should be great. Given the chance, the new rules with the 25.5's should tighten things even more and the racing will be better than ever.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline
Old 12-31-2009, 04:08 PM   #7387
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:12 PM   #7388
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:12 PM   #7389
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Now What???
So I just spent in the last month hundreds of dollars to set up my self and my 2 sons up to go racing in the VTA class. I have just purchased 3 speed controllers, 3 21.5 motors and such equipment. Now you are suggesting I go out and purchase 3 more spec speed controllers as well as 3 additonal motors or motor upgrades, new gears and such so I can conform to the standard rules...
I just got started and now already cannot afford to swap everything out as well as when myself and my 2 boys are ready to move up to a higher level of racing I would then need to purchuse even more esc's in order to be competitive.
I think the rules really need to take into consideration the abiilty to mutli-task the equipment used so people do not need to reinvest to race another class.
One of the major points of VTA racing was that we could all be competitive with standard or slighly old equipment and now we all have to puchase new stuff.
This class has gotten to expensive before I have even really got started!
You cannot expect to bring new people into the hobby and keep asking them to spend money that we don't have!
Drivers in the car... Common it is a hobby!!! You want drivers in the car go race real cars...
Just my -98cents worth!
Happy New Year
JFuel11 is offline
Old 12-31-2009, 04:13 PM   #7390
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:15 PM   #7391
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:17 PM   #7392
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:19 PM   #7393
Daddy'o's Avatar
Thumbs up
Fainting Goats
ROTFLMAO...
Look at the birdie... Looook at the birdie...
Is this what the spin doctor's call diverting a news cycle?
+1
Daddy'o is offline
Old 12-31-2009, 04:19 PM   #7394
robk's Avatar
+ YouTube Video
robk is offline
Old 12-31-2009, 04:24 PM   #7395
robk's Avatar
robk is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
