tire warmers Usefull?
#16
I find tyre warmers an essential with rubber carpet and very useful with rubber asphalt
#18
The computerised Much-More ones are pretty much the only ones available at the top end of the market. Yokomo made some similar ones but I think they are pretty rare now.
#21
I Feel that warmers are as usefull or even more so when practicing. Think about it. If you make a change and head out to check the results you have to run several laps to get the tires up to temp, before you can gauge the results of the change you made. But if you use warmers you can see the change imediately. In only one or two laps you'll know if your change was for the good or not.
As far as what temps to use; I base it on what the outside temp and the track temps are. when the tires are nice and warm the will hold that temp rather well if its a warm or hot day. If it's cold outside, I set the warmers a bit higher to compensate for the heat the will lose while your waiting on the last guy to get to the line. On a hot day I set to about 120f and when its cold I set to about 135f or 140f.
#22
Try hooking the warmers up to an old 7.2V pack. Should help stop the overheating. Assuming it gets the tyres warm enough in the first place on the lower voltage.
#23
CONDITIONS:
-Carpet
-Low/Medium Traction
-Weather: 35-65F during race season.
-Tires: CS27's or CS22's
-Compound: Paragon Black can or Death Grip with Tweak.
-Warmer: Much More IC with large cups.
At first I would run my tires clean with no compound for 8-10minutes. Temp all four tires and this is your baseline. Using my current scenario, my tires are at 79-81F after 8-10minutes of practice. I sauce up and wrap those "Blue Auto Shop Rags" that you can find at WalMart or any Auto store between the tires and warmers. I set my warmers to 95F which will give me a target temp of 80F after a couple of minutes on the warmers. The idea is to compensate for the rags change in temp while warming. I bake the sauce for 5minutes and can run the car as is. Their is no visible "sweat" on the tires and you are ready to go. You can leave the warmers on as long as you want and will not hurt tire performance from my experience. I have ran CS27's for a month consistently until the tires came off the rim. This is only my experience and others may say otherwise. You can also resauce after 5minutes on the warmers or use "Tweak" at this time. "Mrrcguy" has a good point about setting the temp a little higher when extremely cold outside as you are waiting to "tech" or setting up on the "grid". My ideal warming time is 10-15minutes. The first two laps running 27T with rubbers is crucial for me to get in position as my opponents have to warm up their tires. Good Luck and post your own findings.
#25
Are these the ones that will run off a power supply or stick pack?
https://www.ssl-stormerhobbies.com/c....pl?pn=MCHMMTW
I am planning on ordering them tommrow and want to make shure.
#26
Anyone who is ready to buy tire warmers have passed the "friendly race" attitude and is looking for that "edge" to beat the competition. Do it right and get the best. You will save yourself the headache with cheap $50 eBay warmers. Go to "nexusracing.net" and the owner stocks them consistantly. Their service is excellent and can have your item shipped to you before race day. They are based in Georgia which is a plus for us versus going through some Hong Kong dealer who will never tell you an estimated delivery date.
