Like Tree86Likes
Hpi Pro 4
Old 04-11-2005, 02:36 PM
  #10861
rc-zombies's Avatar
Originally posted by Guo Chean
got any difference for this setting is that counter back the steering?
the different droop setting help eliminate or minimize any torque steer from the motor... on stock motors you won't notice it as much...
rc-zombies is offline
Old 04-11-2005, 02:39 PM
  #10862
rc-zombies's Avatar
i using hpi original countersink washer so do i need to tighten it much? bacause that day i read from this forum they say do not tighten too much. so i just leave it free abit.
can you send me your pic how much you tighten it until little bit. thanks
yea..don't tighten it all the way down. just enough to hold with equal pressure on both sides... on mine it's like 1mm from the upperdeck to bottom of washer...
Old 04-12-2005, 04:16 AM
  #10863
jihernandez's Avatar
Originally posted by dizzy1
hernandez- you are way over geared. I run my V2 8x1 with a 74/19 on a midsize track, 50% technical. I run my V2 9x1 usually 74/20, sometimes 74/21. Your comm probably looks cherry red after one race.
Really? How come when I try to gear down, straight line speed is really slow?
jihernandez is offline
Old 04-12-2005, 06:28 AM
  #10864
dizzy1's Avatar
Trader Rating: 29 (100%+)
How is the comm look on your motors? If you comm looks then you are overgeared.
dizzy1 is offline
Old 04-12-2005, 06:34 AM
  #10865
Not really...it's a bit dark but I think it is because of the comm drops. Note, however, that I have 2 fans that cool the engine. Maybe that's why it does not look so
Although I will take a look at your recommendation. I think I should time it. A lower gearing might be faster in the straight-away but not necessarily faster on overall lap time.
Will try higher gear ratios and will let you know of the result.
BTW, since my motors are x2 and not x1, doesn't that mean that my gear ratio will really be lower than yours?
Old 04-12-2005, 10:07 AM
  #10866
TFR
TFR's Avatar
Here is my Pro 4 so far...
TFR is offline
Old 04-12-2005, 12:10 PM
  #10867
Guo Chean's Avatar
hey may i know where can you get those purple screw and the body post o-ring thanks
Guo Chean is offline
Old 04-12-2005, 07:14 PM
  #10868
Hernandez...A couple of points....
1/If you can get the timing on your v2 motors checked...I have three and they were all out!!!instead of 18degrees they were about 24.This could be one of your problems
2/You dont tell us if you are using rubbers or foams...this can make a huge difference,most rubbers are 63mm...given that I run my 9x1 at 23.82 rollout...my 8x1 at 22.74
You can get a rollout chart here
www.arroyoc.com
If you are using foams you have to factor your tyre diameter in.
Barger is offline
Old 04-12-2005, 07:19 PM
  #10869
Sorry I should have explained...
63mm tyre/75 spur/21pinion =22.74
63mm tyre/75 spur/20 pinion =21.65
Barger is offline
Old 04-12-2005, 07:23 PM
  #10870
This is an easier link for gear chart
www.gearchart.com
Barger is offline
Old 04-12-2005, 07:29 PM
  #10871
axel's Avatar
Hey my pro4 is using a fantom stock motor... I have a 48p 70t spur gear and a 28t pinion... My final gear ratio is about 6.02. Should i gear down?
axel is offline
Old 04-12-2005, 08:03 PM
  #10872
www.arroyoc.com
we use rubber tires
Old 04-12-2005, 08:05 PM
  #10873
Originally posted by jihernandez
we use rubber tires
on motor timing - not really sure but it is in the 2nd to the last line (left side).
hope you can further assist based on these additional info
Old 04-12-2005, 09:38 PM
  #10874
Gearing....On rubber tyres on one of the tracks I use( similar to what you have) I would go down 2 pinion sizes ...22...to 20 .for your 9x2. I dont use a 10 turn but would suggest you try the same with that.Check out the gear chart....I use it heaps.
Barger is offline
Old 04-12-2005, 09:44 PM
  #10875
Hernandez...Get someone who knows about motors to check your timing.My motors are 2nd to last line on the RIGHT hand side.The end bell screw on the positive side is in line with the2nd to last line on the can.Hope this helps.
Barger is offline
