Hpi Pro 4
#5881
Originally posted by Pit-racer
Why are you guys putting the antenna on the center top plate?
An Rc answer is...less glitching
or it just looks better on the upperdeck and to make room for larger electronics on the chassis.... the upperdeck is drilled to accept the stock antenna mount.
Basically...It's pretty much drivers preference...
#5882
Originally posted by rc-zombies
A scientic answer is the antenna tube is centered and air drag is equal on both side of the car... if mounted away from the center like on the stock location on the lower chassis... there is more air drag on one side of the car causing it to turn in one direction. you will then have to trim the steering to compensate.... If you raised it higher, isn't that more surface to cause air drag?
#5883
I know about glitches
What else would you like??
...and I'm still waiting for my purple xenon tape to arrive..
#5884
why cant u ppl just run a stk car like the rest of us and not spending money of eye candy stuff and use it toward batts and tires ect... ill get a pic up of my *STK* hpi car shorty lol
lazy
lazy
#5886
ok u got me there lol
#5887
lazy
lazy
failing that, at least if you lose the race.. you lose in style...
Either way, I'll still win in the pits! muahahahahahahaha
#5888
Upgrades
where do you guys get all the purple bits from. i only got servo mount and heatsink motor mount i crnt find any
#5889
Shims
How many shims are you running in your rear diffs?
I run mine as per kit and keep having problems with the rear diff skipping over the bevel gear, it keeps happening and its getting annoying
#5890
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Has anyone recieved the upgraded kits yet(gear and outdrive wise?.....
and where did you purchase?...(just want to know who has the latest kits.....Tower or Horizon)...
#5891
Where to get HARA speedcontrol?
#5893
Re: Shims
#5894
Thanks I'll try that.
#5895
