Hpi Pro 4
Super Moderator
Originally Posted by trjracing
Bxpitbull is Bxpitbull.
540 silver can in a pro 4
gentlemen
anybody running a 540 motor i a pro 4
thanks
thanks
Howzit Minnesh,
i am running a 540 in a Pro 4 now as well. what do you need help with?? did you come right with the gearing??
howzit
paul hi
seem to have got the 48 pitch to mesh however not perfect
maybe u ca take a look at it
running a 66 spur with 34 pinion what do u think
maybe should also run rubber tyres instead of foam
let me know
thanks
minnesh
let me know
thanks
minnesh
with the 66/4 combo and 64mm(rubber tyres) tyres, you will be running a rollout of about 42.5mm. that should work well. you can still go up 2-3teeth on the pinion if you need more speed. but at the same time monitor the motor temps, 'cos it's going to run very hot.
setup is critical with rubber tyres as they can be very temperamantal. foams offer more grip in our type of racing and they are easier to set the car up with, you just have to check the wear patterns and rates and obviously alter your gearing as the tyres wear down.
maybe start with rubbers and see how it goes from there for you??
thanks
66/4 what do u mean
when u say go up a few teeth do u mean if inm using a 34 pinion i should go to 37or 38 or should i
go lower
what does going up mean???
thanks
minnesh
go lower
thanks
minnesh
Originally Posted by minnesh
66/4 what do u mean
go lower
thanks
minnesh
go lower
thanks
minnesh
a change of a tooth or two can make a dramatic change to the way the car performs.Also remember gearing for speed doesnt mean the car is going to be fast around the track.its a balance between decent speed down main straight and good acceleration between corners.Biggest gain can be gotten in the tighter sections of tracks if you geared for punch/acceleration ,added bonus is that motors are not as strained and temps are a bit cooller.
just remember to keep an eye on how hot the motor gets as paul suggested.
When i ran 540 noone raced on foams except on carpet. But we dont have any carpet tracks in sydney.
66/4 what do u mean
go lower
thanks
minnesh
go lower
thanks
minnesh
yes, a few teeth up on the pinion.
Originally Posted by Marcos.J
typical Marine ohh rahh!!
Has anyone tried rubbers, i used to run maximum 28s if it wasnt hot then you might run 24s.
If you use Sorex inserts medium Cs (IE a low profile insert, you want an airgap in the tire). I now drill two 2mm holes in the rim but thats probably not necessary in 540.
Take Off 27s used to be pretty popular and the new next generation sorexs are probably a little better.
no doubt. trj, you rican bastid, just make sure the wife has the pate pateillo however that beef in the fried shell for UFC in two weeks. A lil ruckus keeps the thread going. Yub yub, you right, I like beef. Shoul've seen me in the Losa JRXS thread, I was in rare form. In there, I meant it!
