GM Brushless
#2221
anyone tested Team Orion 4.5 or 5.5 with GM75?
running 12th scale wanting an idea on rollout?
#2222
Yes Jorge,it's a GenII esc . I've allready installed Bootcamp and Win7 on my MacBookPro . I 've also ordered the USBporgrammer and some motors to try the difference between the Graupner Speed and the GM Pro but these are out of stock for a while in the Graupner site, it'll take a while to get the whole order ready to be shiped. I'm still confused about wich programming card to get. . . i assume this is the right one: https://shop.graupner.de/webuerp/ser...I?ARTN=2894.12
#2224
@ghiro - Like i said before i have zero experience with program cards, so i can't help you. Sorry. about the motors have you tried planet-rc? Or send an email to [email protected] i'm sure in less than a week he can help you.
#2225
For example 97290 has very smooth power, great top speed and low temps.
6564 has incredible acceleration and punch but harder to control temps/fading, in touring car.
I prefer the feel of the Graupner every time but often I am faster with the standard GM motor
#2226
Its best to have both. For different track layouts and grip level. For your driving style also.
#2227
#2228
Thanks hana and chris.
The torque may not suit very well the 12th car style. Still in open mod they use monster motors 4t or 3.5t and they still add some timing on them. Should this not mean that there is something to do with a more torquey motor?
I guess i'll continue with the SP V3 i have for now, those graupner are difficult to get here and much more expensive than the other motors.
Anyone has a setup for 12th car? I haven't run my GM esc yet. A few posts back there was one setup but on a 11.1 file (from the GM site). Can i still enter the data on the v13 firmware? Or are they not relevant for this firmware.
Or should i use the v13 made EZ guidelines. Someone said to lower the fixed timing in 1/12 compare to TC. I though it would be the opposit since the car is much lighter, and that i should instead lower the switch rpm to make up for the lower voltage.
Anyone has thoughts on that to help me out.
#2230
@ghiro - Try to follow this V13 How To , if you can't find a way in a few days i will be getting some training and i can give you some setups for TC 13,5.
@hijinx - Different ESC make a huge role in a fdr. I just have experience with GM ESC, try the Tekin thread, maybe someone could help you there. Sorry.
#2231
graupner sport 13.5 6564 versions ..update
Hello, I tested at 6.6 volt life (I hav no 7.4 battery at the moment...) and looked at the motor more in detail: it go ok and havo no hardware timing so there is no problem using high speed timing software, the motor pull strong and with 18° timing have very good high rpm power, about the stator coil, there is only different position of the front triangle where the coil wire is soldered, that is positioned casually unlike the newer motor but that make no difference I think...it may have a bit more coil wire. about the sensor position and magnet the motor have to be shimmed more in the front to take the rotor closer to the sensor as there is a bit of play that may alter the sensor reliability sometimes...that is corrected in the newer motor as it have no play and the sensor is closer to the rotor...apart from that performance should be the same...
regards and good 2011 to all...
#2232
Thanks I will order one now
#2233
Martin,
Can you tell me which fan do you use on your stock car
#2234
Is it possible to advance the physical timing on a GM97290 10.5T motor?
#2235
