Where To Buy 'Old Style' Novak 13.5 BL?
#16
The orginal bonded magnets looked different from the new EX version.I took one apart last weekend and the new bonded have brass sleeves and look like gray plastic. I had my orginals but can't find them presently.We changed the rotor and endbell to the Sinstered rotor. My protype motor is still working fine.
#17
So, in summary, I've seen three different bonded rotors:
1. SS - Grey magnet, smaller bearing
2. Updated - Black magnet, larger bearing
3. Velociti Bonded - Black magnet, larger bearing, wrapped in material
Maybe one of the Novak guys can clear things up?
Also, UN4, are you talking about the circuit board that the Hall sensors and temperature sensor are mounted on that's down in the can? Was it green in earlier motors and orange later?
#18
Novak Bonded Rotors:
1. http://www2.towerhobbies.com/cgi-bin...?&I=LXJXS2&P=7 (SS)
2. http://www2.towerhobbies.com/cgi-bin...?&I=LXNKW0&P=7 (SS Oversized Bearing)
3. http://www2.towerhobbies.com/cgi-bin...?&I=LXMYK0&P=7 (Velociti)
#19
So which bearing comes in the EX series...large or small?
#21
You have to put them side by side to see. But the green one had more Rpm than any of my orange ones. Smoke, Jaz, or henbeave bought it. I'm not sure who got which one.
Thats what I thought he may want is the green one. (Sensor)
They were 4300. But the 1st 13.5's had them to.
#22
The Hall Effect sensors are how the ESC know the position of the rotor. You can read up on them to learn more, it's a pretty neat deal. Having a sensor to tell you the exact position of the rotor seems to lead to a much smoother response than trying to rely on back EMF like the sensorless guys do. I believe that's what you're seeing mounted to that board, along with perhaps a temperature sensor? I can't imagine the color of the PCB would make a difference, but it may correspond to some kind of change made in the motors at the same time that affected speed?
What rotor did the 13.5 come with originally? I know the first 30 or so shipped with the SS rotor (and smaller bearing) but didn't the rest have the larger bearing? If so, presumably, they ran with the updated bonded rotor, right? So maybe the EX actually is different, if that's the case.
#23
Only one problem with the grey and darker material theory. I have the protytpe 13.5 motor. Actually I got two of the orginals(the test models) they they both had the darker brown material magnets.The replacement magnets that I got from Novak was the same dark brown material.The only other 13.5 I've seen was last weekend the new EX and it had a grey magnet- which we changed out to the new endbell and sinstered rotor.
#24
They are visibly different. (Green from Orange).
#25
I have an older bonded one sitting around. PM if interested
#27
Super Moderator
Lets remember guys that there are two bonded rotors... the original used with the smaller bearing and the upgrade rotor/end bell with the larger bearing. However the original SS13.5 came with the upgraded rotor/end bell so just make sure you get an upgrade rotor if you go the route of swapping out the sintered.
#29
The EX sport is what you are looking for...........it does have the rotor you are looking for and will be legal for your club racing.
No further answers required at this time.
