BMI's DB12R
#3542
Just about ready to pull the trigger on the kit, seem to have misplaced my ofna toolkit, what size hex is used in the kit? and what size are the wheel nuts?
People around here seem to be useing 48p mainly because they can take more punishment.
I descided on the lrp 2007 and x11 6.5 motor according to lrp rollout should be about 34mm.
78/18 stock tire would be about correct?, and 78/19 as the tires get smaller?
Oh what pinion would be the correct with the spur supplied in the kit might aswell get one of those too.
Wow car is only 250$ but my total is getting close to 1100$ lol
Do i need to order the sensor cable seprate or does it come with the esc or motor? a combo was not awailable, would a 100mm cable be to short?
Would Elite 4500 cells do ok?
#3545
#3546
Jason,
You got PM
You got PM
#3547
pivot insertion tool..scottrik. Where is that from?
#3548
I was referring to the IRS one Adrian mentioned as being online now...along with the balance buttons. The pivot insertion tool is one place I disagree with Niftech...their tool is better than squeezing them in with pliers, but not by much (it's basically a shaped punch). The IRS insertion tool, otoh, is a DELIGHT to use. And cheap too for what it is. I'll never hesitate to recommend it, and if Jason's got 'em all the more reason to load up the cart if you haven't got one.
#3549
