Team Orion Vortex Brushless motor
#407
You can also heat up the fan with a fat tip soldering iron around the area where the fan is glued to the magnet. When you see the epoxy bubbling pull the fan off with some pliers. Then you have to re-shim the rotor the same amount of space as the fan.
#409
last Sunday i've been practicing with this motor, i use vortex 4.5 with 5 cells....weather a bit unpredictable after several minutes of rain wash and stop, i try this motor on 1/8 track long straight.....i was gear it 7.0 FDR. after 5 minutes test the temperature below 44 degree C. I think i can drop the FDR to 6.8 but it's recommended by the manual 5 Cells Large track FDR 7.0--Is this a starting point or the max FDR i can use?
