Core RC 5000mah Lipos...
#109
#110
this is also the balancer I have coming
#113
Any luck on the balance plug?
Might be a moot point if I buy an ICE Charger. But if I use the FMA CellPro 4s I need to know the adaptor.
Also for storage do these need to be kept at a certain temp? Can I keep it in my unfinished basement that gets around 50-60deg?
#114
Hi Guys,
Balance port (should you choose to use it) is: JST EH type.
Plenty of adapters to this or that are available online, just type in JST EH.
Thanks!
Thanks!
#115
Temps for storage don't really matter unless it's in the trunk of your car on a hot sunny day and it gets over 140F.
In the basement is totally OK.
#116
Thanks for the info on the adapter and storage. Got my Core 5000s yesterday.
Basically for storing it after racing this is what I am planning. Repeak battery before the main, run 13.5 Rubber 5mins, then done. Go home. Is there any reason to really put more milliamps back in to the pack?
#117
Nexus,
For me, 5mins with a 13.5 on rubber eats up about 1200-1300mah. That's just fine for long term storage (more than a month without using it). You just don't want them sitting long term all the way full.
