The prototype car is on the winning pace >
Old 04-19-2007, 08:54 PM
  #91
ttso's Avatar
I check previous photo again, the motor-shaft-90deg-gearbox is indeed on right side of chassis. Interesting stuff, like to see how it designed.
ttso is offline
Old 04-19-2007, 09:12 PM
  #92
WTF! That Reflex Touring car has a modified Losi XX or XXT chassis!
Keyz is offline
Old 04-20-2007, 01:02 AM
  #93
Patriiick's Avatar
Originally Posted by rough512
Don't be. It's a leg pull.
In soviet Russia, leg pulls you.. !!!!
Patriiick is offline
Old 04-20-2007, 11:02 AM
  #94
bxpitbull's Avatar
Default Ruskies, the masters of propoganda
Let's give the ruskies a chance. Only thing that comes from that side of the planet is good vodka and caviar<----if thats what you are into. If a decent tourer comes out that lends a totally different concept as to what we've grown accustomed to seeing, lets give it a fair shake. If it does well, kudos to them; if it crashes and burns, well, somebody will be headed to the gulag or siberia.
bxpitbull is offline
Old 04-20-2007, 11:33 AM
  #95
Big B's Avatar
Looks to me almost like a home built car, the diffs are from associated (pretty sure), antenna mount xray, front upper bumper xray, the hubs all the way around almost look like xray aluminum rear uprights, the upper a arm is a couple of shumacher turnbuckles, lower arms look like xray, etc...
Big B is offline
Old 04-20-2007, 11:46 AM
  #96
rc-car-net's Avatar
all these parts are for the prototype!! they'll produce all products by them self after the dampers are patented.
rc-car-net editorial office devision told that they'll soonest start in october/november. more news in a few weeks.
rc-car-net is offline
Old 04-20-2007, 11:58 AM
  #97
Big B's Avatar
Ok Ok, no need to get all worked up and start using exclamation points. Acutally with a little work it could easily have 4 wheel steering, very interesting
Big B is offline
Old 04-20-2007, 04:55 PM
  #98
No Shocks, sideways mounted motor in a shaft car. This thing is the work of the Devil!! It's evil I tell you...EVIL!
DOTMAN is offline
Old 04-20-2007, 04:57 PM
  #99
Originally Posted by Turbokisa
Hey guys, look at this nice photo
It's opening ceremony of Russian Cup 2007.
Well heck...no wonder the car did so well. Two of the cars in that pic don't even have chassis'. I know there are some poor folk in Russia but...
DOTMAN is offline
Old 04-20-2007, 07:10 PM
  #100
Wolf's Avatar
Default Is it real ?
What is the white disk like object next to the motor ? Spur ?
Why is it there ?
It's hard to tell from the picture how the motor can drive the shaft.
Can you tell how's the steering work ?
And, how to mount shocks ?
Is this car for real, or it's just a joke ?
Wolf is offline
Old 04-20-2007, 09:45 PM
  #101
Big B's Avatar
cant tell but the shocks may be mounted like a M18, inboard
Big B is offline
Old 04-21-2007, 01:12 AM
  #102
Turbokisa's Avatar
Absolutely real.
Turbokisa is offline
Old 04-21-2007, 04:50 AM
  #103
myndesye's Avatar
Exactly, if you are not using the sides of the spur gear, what is it there for? Unless you set screw the output shaft directly from the motor, into something that goes through a series of gears, including a 90 degree transfer, to another output shaft, going to a tradional spur, in the traditional manner.
The Search Engine Where They Search For You
http://try.chacha.com/?rid=2536
myndesye is offline
Old 04-21-2007, 07:06 AM
  #104
rough512's Avatar
Yes, I too was wondering about that. You will also notice that the motor is too close to the spur gear, how did they fit the other gears between the motor and the spur gear. And wouldn't all the gears needed to do the 90degree transfer, etc defeat the supposed efficiency of the shaft drive?
rough512 is offline
Old 04-22-2007, 11:52 PM
  #105
Why is it there ?
Yes, the car is real and you see the spur ))
As for shocks - even when you see the real car, you won't guess at the moment where it is, because it doesn't looks like a shocks you used to see in every touring car.
number_one is offline
