Alex Racing Barracuda R2 & R3
#5686
Originally posted by SpeedTech
Hi guys,
One thing I noticed, and for those that have been having front one-way problems with the one-way bearing pins. You might want to check and make sure that there is O-ring spacer in the outdrive. This will ride against the universal dogbone to prevent the outdrives from coming out of the one-way housing. Without this Oring, the one-way outdrive will work it self out of the housing and then the outdrive will only be riding on a portion of the one-way bearing and the bushing on the outside. This puts a lot of stress on the one-way bearing and it can cause the pins to move in its housing. Guys with quad bearing one-ways won't have to worry about this I assume, but it's still a good idea to have the Oring in there
Steve Wang
Hi guys,
Steve Wang
#5687
R/C Anonymous,
It pushes because it has too much rear toe-in making the car too stable in the rear. The A6113 rear hub will reduce it by 1 degree and the off-set center balls can reduce it by another 1 degree. That should help free up the rear end a bit. Another thing you can try after these adjustment is putting a shim (from the A6511 shim kit) underneath the front rear suspension ball mounts (just a 0.5mm can have a pretty dramatic affect) that should make the front dive even harder into the turns. Give those a try
Steve Wang
R/C Anonymous,
Steve Wang
#5689
R/C Tech Elite Member
Originally posted by johnny55
Steve I guess this is the perfect time to ask you how to exactly use the the off center balls. Do I use only two in the rear or four? Also where do I want the lines to line up? Thanks. I am using the A6113 rear hubs.
#5690
anyone know where i can get red aluminum body posts for the front?
any help would be appreciated.
Thanks!
Thanks!
#5692
Regional Moderator
Thanks!
Thanks!
Atlas has some nice ones also
#5693
that's cool, Thanks guys!
#5694
The ball stud themselves are not off centered, but the screw holes for these are drilled off center. The side that the screw hole is off centered to, there is a line (or notch) and what you want to do is lined up the notch straight as much as possible. To reduce toe-in, for the Rear Rear ball stud, have the notch facing out and away from each other. to reduce even more, you can have these off centered ball stud on the Rear Front mount and have the notch facing inward towards each other. If you're out there on Sunday at the Toyota race, I can show you then.
Steve Wang
#5696
Tobee Craft makes blue ones for Yokomo, which are the same as the R2 ones.
Steve wang
Steve wang
#5697
Regional Moderator
Heath you get that cuda together yet? and are you ready for nov 1st
#5699
Randman,
I should be, but I'll need some power to charge though...I'm not sure if Dan's got that.
Steve Wang
Steve Wang
#5700
Regional Moderator
