Alex Racing Barracuda R2 & R3
#2957
OOH PINK!
I think that car needs a Barbie shell
where did you get the pink tunrbuckles?
#2959
oooh aite, so outdoors i should definitely use it?
#2962
Originally posted by Randman
You know I'm thanking you for those Can't wait to try the mid span setup. Can you send me a setup sheet, just so I know what all I have on there?
it should work very well at so call...you just need to run a ALFA 2.0 ..and ...chose a good tire and insert like a Sorex 36R and Xenon Green insert
ALso I take it that you like the pink stuff hahahah
-Dave
#2963
It's a good idea, although I never did...
will it affect performance thats y u dont use it?
#2964
R/C Tech Elite Member
Originally posted by JDM_DOHC_SiR
Sure will I have allready made it up...
-Dave
-Dave
Sorex 36R - check
Xenon green - dont have
Xenon blue - check
Havent messed around with the green inserts, but Dave got me hooked on the blue ones. And you are right, I love the pink goodies!
#2965
Gear cover I found were just a little too annoying. They do keep a lot of grit out, I race on some fairly gritty surfaces outdoors, but they do let the occasional stone in which can get stuck between teeth. You then have to dismantle half the car to find out what is binding in your drive train, or to do something else like change spur gears. I now run without them and yes I have problems with the small bevel gears looking a little chewed after a days racing but they don't need replacing, the diff gears hold up a lot better. You get a few more small gritty stone stuck in the teeth of the bevel gears but you can easily spot them and use a screw driver to flick them out in seconds.
#2966
RE: Pinky
Very nice work Dave...RM can we call that car Mr. or Mrs. Floyd
Dave ....Wish you Were Here
KORacer, as for springs, it seems like stock is a good baseline with te Alex springs 1.4x6.00, you can pick u a few lighter, and a few heavier. So far that's all I've used.
#2967
Made the PLUNGE!!!
I have been reading this thread for couple of weeks and you guys have convinced me to try it out. Thanks JDM_DOHC_SiR
for your help I really appreciate it. I just placed a big order with speedtech and hope to have the car and the other hopups next week. As for the aluminum shaft holders I figured I needed 2,one for the front and one for the rear. I also ordered the pal system and also the ball studs so I can adjust the rear toe. I still need to order some springs and sway bars so I need a little help. I am going to be running on ozite carpet with foams and a 19 turn motor. The track is sometimes technical with a lot of turns and fairly smooth. Actually here is the site where I race and just click on the indoor pictures to get a liitle idea what I mean. www.ajsraceway.com. Sorry for the long post i'll shorten it for now on. Thanks
Kevin
Kevin
#2968
I havent heard of the Pro-Traks here stateside, do you have any info on them?
anyways,
I have info on it, well because I own one here in the states. Actually a fellow racer of mine and I both have one, I think the only two in the states. Shipped to my door, took 2 weeks, and cost 340 USD. I have had mine for about 3 months. I like it, I just bought the GFX at the electric onroad Nats, and I like it better, except for the size.
If you are just interested, email me, and I will answer any questions you have.
#2969
Originally posted by Ko Racer
when will the site be up for fukuyama batteries?
Dan
#2970
Regional Moderator
dave .... very nice job on pinky
red bull .......thanks for the info and im sending you something to try out on your cuda .
