Yokomo MR-4TC SD
Originally Posted by coastaltony
FOR SALE
I'll take 1 fan...
send me a paypal invoice to my email address...
Originally Posted by Matt Howard
Yokomo has their version of the new VFS-1 Competition esc coming out as well.
those are the new generation VFS-1 with carbon case.
newer fets and higher Temp cut-off.
Originally Posted by pops
You are so right about the fan, not only for the speedo but for the motor. We did not run a fan at the Speedworld Cup, and the Quantum 2 was fine as far as I could tell, but the motor got so hot that the soilder on the + brush melted and the brush came off. The + spring actually melted to remove all tension from the spring as well. I think if we had a fan on the motor, we would have done much better. This happened on the 1st and 3rd A main at about 4 minutes into the race. I am working on a fan mount for the BD this week.
R/C Tech Elite Member
Originally Posted by Hebiki
hey pops.. quick question. curious if......the pro guys are attaching fans to the heatsinks of their esc's, are they blowing air INTO the heatsink? or sucking air out of it? thanks!
Originally Posted by Pro4Capece
I'm running an open 19turn class. That means that I can build a KC handwound motor at 40*timing . Only problem is that our track is very technical then has back2back braking zones, then a long 200ft straight. So my motors get scorching hot!!!! I'm using the Reedy fan/heatsink device. I've only used it once, but it made a noticable difference on the endbell temp. I've also got the RIDE cool air scoop to channel air over the can. My non-XXX brushes look just like yours after one run, but some 767's looked fine after the fan was used and I put two runs on them.
tell the kid to lay off the throttle a little bit, LOL
FOR SALE
I haven't even seen or noticed any fans on the ESC, just the motors. Running a Q2 and haven't noticed any problems with overheating. I might be wrong, because I don't know that much about electronics, but it would seem to me that if the motor ran cooler, in turn the ESC should be cooler too.
When we ran a SD we would put the fan in front of the motor, behind the ESC, drawing air off the ESC and blowing it on the endbell of the motor. Haven't put the fan on the BD yet but will shortly.
I forget the site I got them from but I will check my past emails to see if I can dig it up.
-Stephen <><
5v
How many volts is the fan rated at?
5v
Coastaltony the two aluminum pieces (look like heatsinks) and screws that are next to the fan how are they used?
-Stephen <><
I am trying to get a small sheet of Carbon Fiber to make me a mount for both the SD and BD...I think I can make something that will work and also not be too obtrusive to look at either...Gotta look good beat you all...LOL
Here is a picture. Check out these sweet motors. Wait till I run against A.H. again. All I can say is look out.
Fans From R/C Innavations
Hi,
Thought you guys might like to see this. They are from a company called "R/C Innavations" Cool-Can-Fan's over here in the UK. This one i believe is a prototype for the CGM, but he also does them for SSG and BD and all other manufactures and they work like a treat .
If you would like to know anymore, take a look here and post your question. Or you can contact one of there main distributor's www.c-sracing.com
Cheers
Cheers
LCG
Questions. . . . . our track is a little bigger than 2 tennis courts, smooth asphalt, moderate grip
The LCG really flexes, what will I expect coming from a CGM that is super stiff? Handling wise? will it be "twitchy?"
I use WHITE RS Springs all around in my CGM, will that also work with the LCG or will I need to go softer?
Lastly... dunno if this has been asked before, but I was just wondering....
Is there any effect on a Shaft Driven chassis that flexes, if I use a One way or a Spool? Will a Spool flex the chassis more than a one way?
Almost done with my LCG!!! excuse my ignoramous questions.......
the things you think about at 2:30am!!!!!
