Yokomo MR-4TC SD
#4501
All SD owners: Need you guys advise. If I'm mounting the servo horizontally on my SSG SD, must I align the servo horn at 12 o'clock position or to provide 2-3 deg. off set just like the TC3 /Rayspeed SD???
#4502
Kilruf: I have a couple questions about your setup.
First, on the setup you say you're running the top mounted swaybar up front. How does it fit? Isn't the front shock tower too wide, or are you puting the swaybar over the shock tower?
Also: I noticed Masami also runs the top mounted bar. What's the advantage to upper mounting rather than lower mounting? I run on carpet, would an upper mounted sway bar be better for me too? What are the differences in handling?
Thanks.
Thanks.
#4505
R/C Tech Elite Member
Originally posted by DickemDown
i picked up the suzuki hubs after reading a few pages back about the trailing arm - not sure who posted it. anyway, they had wrote that gives better steering response, and he was right. it feels a little twitchy, but i'm starting to get used to it. i actually got 'em because i kept stripping the hole where the kingpin goes.
#4506
Originally posted by vtl1180ny
I broke both the Knuckle and the C Hub... I'm seriously considering taking the C Hubs to a machine shop and seeing if they can duplicate a set of aluminum one's for me... In the srping I have a CNC mill coming to me, but I really don't want to wait... One good thing I am getting for the mill is a probe which will allow me to make exact copies of parts. I've already got a delrin and nylon supplier setup...
#4507
Originally posted by rcfiend
Randman - how did you like the Barracuda?? Any tweek problems?? How does it compare to the Yokomo??
#4508
Aluminum parts
The major part with aluminum parts is this. You make one part stronger, then something else has to give, maybe a arm, a suspension mount, or even possibly the chassis. I think that with the suzuki spindles, graphite parts(arms and cases), and aluminum suspension mounts, I think it would be sufficent enough.
Also aluminum does bend! If you are breaking c-hubs that much you are crashing to much. Now imaging this, if you think you have tweak problems now, try setting tweak with a bent c-hub, arm, arm mount, spindle, or whatever else made of aluminum. It will drive you nuts. Take it from experience(my own).
So, my belief is that the less aluminum the better.
#4509
Dickem, I haven't really tried a oneway with that setup. The track was wet, so I had the take the oneway out. Then it dried out and the traction came back. But I kept the diff in and worked with the setup.
Cool, the upper swaybar will work depending on how far the shocks are mounted out. I'd prefer the lower swaybar for carpet.
#4512
Have any of you guys had a problem with your batteries falling out. If so, what can be done to prevent them from falling out??
