Yokomo MR-4TC SD
#1831
Originally posted by Randman
The chassis will flex more, propably give a little better traction on looser tracks. I thought the chassis flexed a little too much without the stiffener, but I wanted to get a little more flex than stock, so I went about cutting up the upper deck. I got the results I wanted, with a flex that feels "inbetween" having and not having the chassis stiffener. I also noticed that when I would twist the chassis by hand, the left rear of the car would stay tweaked up, and as soon as I loosened the screws on the upper deck, it would lay flat again. With the cut upper deck, the chassis holds no tweak. I will upload the pics of the upper deck right now, and post them in a couple mins.
I'll try doing away with the center stiffener first and see what happens.
#1832
Re: Re: Universals and bones..
Originally posted by marzin
Hi,
Anyone experiencing the same problem? Seems like quite a number of complains in this area?
Care to share and wats the remedy?
Thanks Joe
Hi,
Thanks Joe
After I broke and axle...I switched to M.I.P's and never had any problems. Just purchase front and rear MR4TC and you are all set. Don't worry about getting rear dog bones for the front...they do not fit. somehow they are too short for the front. I've got shinny front bones and aluminum in the rears.
#1833
R/C Tech Elite Member
Originally posted by Explorer
Thanks Randman. Nice pics too!
#1834
Yokomo spring rates
Can someone verify if this is correct?
From softest to hardest:
YS-1360 black
YS-1355 blue
YS-1465 white
YS-1460 fluorescent yellow ~ 12 lbs
YS-1455 flourescent green ~16 lbs
YS-14525 stainless
YS-1450 orange ~20 lbs
YS-1360 black
YS-1355 blue
YS-1465 white
YS-14525 stainless
#1835
Re: Yokomo spring rates
YS-1360 black
YS-1355 blue
YS-1465 white
YS-14525 stainless
YS-1360 black
YS-1355 blue
YS-1465 white
YS-14525 stainless
Visit this website:
http://www.schumacher.clara.net/springchart.htm
#1836
Muchos gracias.
#1839
That's killer, I was wondering what the yokomo and associated rates were, everyone is talking about running associated springs on the car, so I think I will give it a shot too.
The SD comes with stainless springs, not silver right?
if you're going to change to AE springs don't forget to change your shock ends and spring retainer.
#1841
The easiest thing to do is use ballcups for the bottom shock ends. That is what most of the factory guys are doing. You can see some pics on my website. www.mo-net.ws
#1844
jeff this saterday I ran asc. blue in the front and silver in the back, AE 40 wt. oil, and #3 pistons mounted in the stock position this setup seemed to work pretty good at mikes. Although I only got to run two races. I think it's just driver preference I was using AE spings because I already had all of them from my tc3.
#1845
I just picked up a set of green and silver for the SD, going to run green in rear. Hopefully it will be a descent setup to start out with. Just ordered a bundle of parts from Rainbow Ten, including the Suzuki steering knuckles, tobee craft driveshafts, square axles, and a bunch of misc stuff that is hard to find stateside. Can't wait till I get that order!
