Team Corally RDX Phi
#466
Originally Posted by yyhayyim
What I mean is, that the asphalt/outdoor kits, dubbed "EU/UK" kits, are the ones asphalt racers run...most of these drivers run spools- not oneway; it doesnt matter if you live in the UK or USA, the rubber asphalt kits are supposed to or should be catered to the needs of asphalt racers, of which 99.9% run spools now adays...With the carpet kits, those who buy them run on carpet and use double diff set up most of the time. How come they get the double diff, while aspahtl racers have to spend extra money on a spool which should be the set up on asphalt kits to begin with...
#468
The kit I recieved here in New Zealand contained 2.9mm lower chassis-2.4mm upper,ball diff front & rear(U.S kit )but 3 degree caster blocks & standard black shock springs(U.K kit).I have had my kit for a week and a half now and I am led to believe that was when the kit was released here in NZ.Nearly all racing down here is done outdoors on asphalt.
#469
Originally Posted by edseb
No one has them in stock yet. Superior Hobbies is the distributor for Corally in the USA and some of the team has been starting to get them in their pre-production kit form. They are the same car as production just missing a couple of parts. It was decided to get the cars in to the team's hands a little early so they could try to get used to it by the Reedy Race even though there are some small parts needed to totally complete the kit. Entire kit for the market should be here in shops in the next couple of weeks.
The only thing that I have heard that was missing was the new center pulley design.
#470
Suspended
Hey whats there number?
Scotty has allready cashed my check for my RROC entry...Word Homie...
#471
#472
RDX PHI
I am going to pick up my kit in michigan on sunday,I can't wait.Its a little more than I wanted to spend but I got alot of parts for these cars .Also I refuse to jump on the X-RAY band wagon.I hope some other racers in Illinois are going to run RDX cars,swapping set-ups helps alot with a new car.
#473
Suspended
Originally Posted by Yeti35
Hey Bitter, you could always do what your boy Ertrachter did.
#474
RDX -PHI
I got my kit today and it is awesome I can't wait to get it together
#476
Was at the track today and saw brad johnsons car run some 19t foam and the car was dialed.... very good craftmanship on all the aluminum and the car is a thing of beauty
#477
Has anyone had the same problem I'm having. I can only screw in the ball stud on one side of the rear uprights. It's like having (2) lefts. Snaped one ballstud trying to screw it in. I'm getting alittle pissed, since corally sent me (2) new ones to fix the problem. And the same thing is happening to those. Now I have (3) lefts.
#478
Peter
#479
If you look one side of the upright looks to be "counter sunk" with the uprights being zero deg. they can be used for either side of the car...I bet with the 2 deg ones the "counter sunk" side is right.
No big deal. I just took the longest screw I could find in the kit and ran it thru a few times from both sides. Then treaded the ball into the side I needed.
Hope this helps.
#480
Originally Posted by imprsme
Yeah Juan I had the same problem...
Hope this helps.
Hope this helps.
