CRC's New Generation-X.... Your Thoughts? >
Old 11-27-2008, 12:40 PM
  #1396
t4mania's Avatar
How good is the Pro Strut front end on these cars. Thinking of picking one up.
t4mania is offline
Old 11-27-2008, 01:00 PM
  #1397
espresso1967's Avatar
Trader Rating: 18 (100%+)
Hmmm, good quesiton. Compared to what? This is the only rc I own so your asking someone that has been in it for a year. If you follow some of John's links, tips and tricks it is a smooth strut but again I do not have anyting else to compare it so all I can say it is good.
espresso1967 is offline
Old 12-07-2008, 05:17 AM
  #1398
Frank,
You have a PM!
Jeremy Otis is offline
Old 01-07-2009, 07:08 AM
  #1399
buffalobill989's Avatar
Trader Rating: 50 (100%+)
can anyone tell me how i can tell the difference between the .45mm front springs and .5 springs? im getting ready to replace the one on a car i bought and im not sure whats on there. ive got the stock .50 springs. when would i want to consider going to the softer springs which is the .45 i assume?
buffalobill989 is offline
Old 01-07-2009, 07:13 AM
  #1400
If you have calipers you can just measure the diameter of the wire withing the coil. If they are the kit springs I believe they are .50's
Old 01-10-2009, 05:21 AM
  #1401
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey Guys i need some advice. I was wanting to buy a open conversion kit for my Gen x. (Pn. CRC-3339). I was wondering is this needed if i buy the offset pod for brushless motors. (Pn.-CRC 3349)
Should i buy one or the other, or get both.
Yokomo_Ant3 is offline
Old 01-10-2009, 07:10 AM
  #1402
rpoage's Avatar
If you are going to run a Brushless set up:
You will need the CRC 3349 Brushless Offset Pod for Gen-X.
Depending on what version of your car you have it could have the CRC 3339 Open-X Rear Pod conv - Gen-X on the car already, At the very least you will need CRC 3337 Red Hex Standoff Open-X Pod which comes in the CRC 3339 or can be purchased seperately.
The (CRC 3338 Left side Bulkhead for Open-X) is the same as the (CRC 3342 Left Bulkhead - Gen-X) but the leading support for the upper plate is machined off. If you want to save some bucks and don't care if it looks perfect you can dremel the alloy brace off and get a CRC 3337 Red Hex Standoff Open-X Pod.
Ashford Hobby CRC 3349
Confussed enough? My job is done here
I would buy a spare CRC 1765 Rear Top Plate - Gen-X 10 as they can break. It is NOT the same as the one included in the CRC 3339 Open-X Rear Pod conv - Gen-X
Ashford Hobby CRC 1765
rpoage is offline
Old 01-14-2009, 08:10 AM
  #1403
Frank,
Could you post your Cleveland setup. Tried to open on your websight and it says file damaged. What was your rollout also. You car was a missle!
Travis
march to my own is offline
Old 01-14-2009, 10:59 AM
  #1404
Default Cleveland 2007 Setup
I was in the "A" with Frank. Here is my setup
Front:
Grey Fronts 1.62
50 springs
10 Degree Blocks 1 shim front and 2 back
.5 Degree Camber
0 degree toe
4.0 Ride height
Rear:
Yellow Rears 1.68
Red Center Spring
172mm Track width
4.0 Ride Height
Gearing:
2.90 Roll Out with Tekin RS full timing
Trinity Duo 17.5 Motor
Hope this helps. E-mail me directly if you need any other information.
Steve Dunn
[email protected]
sdunnmcp is offline
Old 01-14-2009, 11:06 PM
  #1405
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
Thanks for the info I was about to ask a question about the Open-X Pod. Is the Open-X Pod the latest offering in the current Gen X kit? Has it been around longer than the brushless motor pod 3342? Which one is newer? What do most people currently run? Thanks.
rcjunkie3000 is offline
Old 01-15-2009, 02:14 PM
  #1406
Is the Open-X pod newer than the brushless motor pod that ships with the CRC Gen X? Do both of them center the brushless motor for even weight distribution? Thanks again.
Old 01-15-2009, 09:13 PM
  #1407
Front:
Grey Fronts 1.62
50 springs
.5 Degree Camber
0 degree toe
4.0 Ride height
Rear:
Yellow Rears 1.68
Red Center Spring
172mm Track width
4.0 Ride Height
Gearing:
Steve Dunn
[email protected]
Thanks Steve.
Did you have the timing cranked on the motor as well?
what silicone did you have in the dampening tubes.
Servo angled or flat?
Old 01-16-2009, 05:03 AM
  #1408
Default Open X pos
The brushless pod is newer than the open X pod. The open X was an upgrade from the original with a new damper/shock mount , threaded post between the pivot ball and damper/shock mount and bolted right up to the original lower plate and X brace across the back of pod . The new brushless pod looks very similar to the open X but it has a new lower plate, x brace, damper/shock mount and a new diff side hub for the axle. Reviewing a few of the posts and looking at Stormer's site, I guess you do need to have the machined down left side bulkhead originally offered with the openX to complete the conversion if starting from the original brushed pod. The kits have been upgraded to reflect the best available tech and do come with the brushless pod. A club member had just gotten one from Stormer a few weeks ago and it did come with the brushless pod.
Mitch
flyernemesis is offline
Old 01-16-2009, 09:40 AM
  #1409
Originally Posted by march to my own
Thanks Steve.
Motor timing was in the middle hole.
Losi 30,000 in tubes
Server angled
I felt overgeared now that I have been using the RS for a while. If i was to do it again I would have geared at about 2.70 Roll Out.
Steve Dunn
sdunnmcp is offline
Old 04-10-2009, 08:33 AM
  #1410
Frank/John
Will there be a 1/12 scale kit in the near future that will include all of the recent upgrades including the longer side links and revised chassis?
Also, will there be a lipo chassis coming?
Thanks,
Jeremy
