The Official 4300 Brushless/LiPo/Foam Touring Thread
#16
Originally Posted by racenut123
Perfect thread!
We are trying to start a 4300 class at our track.Lots of interest but I have a question.IS it 4300 and 19t together or 4300 only?We have tested on a good size asphalt track and found that the motor is so similar to 19turn we were hoping to run them together in order to eventually get more people into brushless.Whats is your tracks class restrictions as far as 19t/4300 running together?
Thanks!
Thanks!
We've been real big here on creating a class that's very balanced in terms of equipment and performance, so we're kinda keeping the 19T guys out of it, otherwise it would kill the spirit of the whole thing.
#17
A "Team Level" driver with good NiMh and a "tuned" 19t can be a bit faster. So we prefer to keep them banished to the "old school" classes
see, I knew Johnny Fast Fingers would beat me to it.
#18
I see where your coming from.A good KD 19t is faster on the straight but the infield the brushless is King!
So the Stock rotor is faster then the sintered rotor setup? I am getting together my gtb/4300/sintered rotor setup but was wondering if the actual stock rotor has better performnce.Then why go to the sintered rotor if that the case?Keep the suggestions coming!I appreciate it.
#19
But, the stock rotor is a giant pile of crap. The magnet slides around on the shaft easily, it fades with heat, and it's noisy as hell with the brass shims in there. Plus, it runs hot and is easy to thermal, which is frustrating.
Grab yourself the ribbed endbell for Velociti motors (not the HV version) and a sintered rotor, put it in your 4300 and you're set. The ribbed endbell is lightened, about 1/2 oz. lighter than the "updated" endbell, which is the same one that comes on the Velociti motors without the ribbed can. It will give you the larger front bearing, which allows you to use the sintered rotor.
#20
Originally Posted by FreqETag
Its a common misconception that Rubber tires last longer and are cheaper than foam.
#21
Also you could flip the coin and say the local fast guy is the one running the Brushless system while the rest of the field is running 19turns.He still wins.Now it appears that the Brushless has the advantage.I am trying to gauge what your experiences are in real world racing.We have noticed in club racing that the 4300 is just different in power band then a really good 19t and thus on the average track there shouldnt be a real advantage to either.I am not trying to start an arguement,just trying to get the facts from those who have more experience then myself.Again keep it coming!
#22
Well, fast guys will always be fast I guess. I think mixing the two is fine, but a 19T IS faster. If you look at the results from the Novak race last year where they had a 19T and 4300 sedan class, it was close, but the 19T motors definitely had the advantage. I would think on a big, flowing track, it would be more noticeable.
I would say they're close enough to run together as long as the 4300 guys don't mind that someone with a good 19T is going to be faster. The 19T guys are probably fine with the idea of being faster, I'm sure it makes them think they're using superior technology. :-)
#23
Also you could flip the coin and say the local fast guy is the one running the Brushless sytem while the rest of the field is running 19turns.He still wins.Now it appears that the Brushless has the advantage.I am trying to gauge what your experiences are in real world racing.We have noticed in club racing that the 4300 is just different in power band then a really good 19t and thus on the average track there shouldnt be a real advantage to either.I am not trying to start an arguement,just trying to get the facts from those who have more experince then myself.Again keep it coming!
#25
We could debate all day about Rubber vs. Foam on Carpet.
I prefer Foam. The idea is there should be a Foam class AND a Rubber class for those that want it.
Most of the other regions I have seen are limiting the Brushless/LiPo guys to mandatory Rubber. Thats what the just did in Omaha.
I think the problem is people (race directors) are looking at it like a "budget class".
#26
Everybody is using the Orion packs right now, so it hasn't been a big deal. You using the MaxAmps pack?
Are all the Omaha guys running the SS rotor? Is anybody experimenting with the updated or sintered rotor up there?
1. Heat.... seems that they are running about 15 degrees cooler so they can grab a little more gear
2. The stronger magnet seems to make the car have better more consistent braking which translates to better drag brake.. if you like that sort of thing.
Like I said not much experimenting so far with onroad but I'm sure as some more better racers switch over there will be guys trying different things.
#27
Right now the 4300 class in Omaha is being driven by budget conscious fairly new drivers for the most part. As evidence to that there were 13 entries in the 4300 rubber class at our recent Midwest Carpet Championships. There were 7 guys with 23+ laps in qualifing and 6 with 21 or less laps. Of the second group 5 were locals. So you can probably see our motivation for the 4300 class seems a little different than KC's. I'm not much for travelling for racing yet but would like to sometime... December might be a good time to try it out since our Enduro is in December and I'll be running foams for that. We'll have to see.
On a side note.... I pitted next to the Fransden's this weekend! Nice folk... Congrats to Shaggy on winning the Concourse! Ok back to our normally scheduled programming!
#28
The way it's working out in KC is that we're having rubber tire as kind of the budget, beginning class. There's some good drivers there though, and a few guys that just prefer to run rubber. We're allowing stock/13.5 in that class.
Foam sedan is generally where the more experienced racers mingle. The 4300 class is the largest, and most competitive. We're using it as an opportunity to have a class with reduced maintenance, and an even playing field. Nobody really minds the foam tire thing that I know of. I don't ever hear anybody wishing they could run rubbers instead.
There's a few guys hanging on to the brushed motors, and they seem to bounce between 19T and stock, depending on the night. We've slowly been stealing them away to our 4300 class, as well as a few guys from stock 12th scale.
There's a lot of very talented off-road guys in this town, and a few of them having been showing up to race some sedan during the winter. Lately, they've been running the mods from their off-road cars in the sedans and having fun with that. They sometimes bounce around into stock and 19T too, depending on the night and the turnout.
#30
This is awsome. Heres my 2 cents and its simple, The stock rotor is lihgter brand new its faster But I think there ceramic. Any how peak performance You would be lucky to get a full night at fast lane we have done it all keep tuned in. About the only thing we havent done is put them in water. we actually almost cuaght one on fire we have ran these motor hard. It is a tuff call. The centered rotor is very fast and reliable its definitly the way to go. Like a new car you just gotta see how fast it will go. If you run the stock rotor I can tell you now have plenty on hand and run the newest in the main.
