Team Losi JRXS Type-R >
Like Tree52Likes
Old 07-19-2009, 06:13 AM
  #9886
Pablo Diablo's Avatar
Bit of an update on the Flying Fox spool. I gave it a good work out on Friday night. It was my first race for a while and the first time on a new track layout, so I tested the spool by hitting the boards a few times hard. The spool still looks like brand new! I also weighed the kit spool(19grams) and Flying Fox spool(11grams) and there is a bigger difference than I thought. I will aim to make the production spools a clean 10grams. Even better is that this will be a 9 gram saving in rotating weight!
Another benifit of using the new spool is that you then have all the parts you need to make a spare diff. I also will be working on a solution to stop so much dirt getting into the diff.
Pablo Diablo is offline
Old 07-19-2009, 09:04 AM
  #9887
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Great work Paul!!!
Spool: maybe you can shave off a bit of weight by only using 3 screws to bolt on the pulley, instead of six.
New Idea: what about designing a new aluminum steering rack? The new rack would be tougher and can have up to 6-8 positions on it to get new ackerman and steering link lenghts and angles
Also, maybe a new CF 2.5mm top deck for asphalt racing, to allow bit more flex, with out having to unscrew the 4 screws of top deck or use o-rings in low -med bite tracks
yyhayyim is offline
Old 07-19-2009, 09:21 AM
  #9888
iPearl's Avatar
Trader Rating: 96 (100%+)
Spammer needs to die ! ! !
Skinned alive and thrown into a tank of salt ! ! !
Then send back to the company ! ! !
Back to the topic.
JRX-S R is the newest Losi Model for touring cars correct ?
iPearl is offline
Old 07-19-2009, 09:55 AM
  #9889
Trader Rating: 21 (100%+)
Back to the topic.
yes
lidebt2 is offline
Old 07-19-2009, 07:44 PM
  #9890
Originally Posted by yyhayyim
Great work Paul!!!
From my experience a stiffer chassis is always faster when you get it hooked up. More flex costs you response and mid corner speed. When I ran a T2 I always started with it stiff too see if it worked before resorting to soft (chassis flex).
Dragonfire is offline
Old 07-19-2009, 09:59 PM
  #9891
MaxRain's Avatar
I have to agree with Dragonfire on the stiffer chassis as you want the mid corner speed. Think of chassis in formula 1 cars, they have to be as stiff as possible to get the corner speed they need. To maximize the corner speed and grip, they tinker with suspension geometry and tires.
MaxRain is offline
Old 07-19-2009, 10:04 PM
  #9892
adamge's Avatar
That's nice to imagine, Max, but look at the results of every major rubber tire touring car race. Again and again, flimsy chassis like the 416 and Cyclone beat crazy-stiff chassis like foam versions of T2 and RDX.
adamge is offline
Old 07-20-2009, 01:09 AM
  #9893
Mayb it the driver?
I changed from the full plastic version of the scythe to the alloy version and picked up heaps of speed! Now I am running the losi and its way stiffer again and faster. Soft chassis just makes it easy to drive but not faster.
Old 07-20-2009, 04:59 AM
  #9894
Yeti35's Avatar
Schreff phrased it to me like this once when I asked about the flexible chassis, do they build flex into full scale race cars to get them to work? If you are making the chassis flex to make it handle better then your setup does not work. I know Schreff and Fairtrace messed with different chassis thicknesses and went back to the stock chassis because they felt it made no difference on this car. Can you really argue that with those two since they were sucessful in big races with it?
Yeti35 is offline
Old 07-20-2009, 07:28 AM
  #9895
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Yeti35
I know Schreff and Fairtraced messed with different chassis thicknesses and went back to the stock chassis because they felt it made no difference on this car. Can you really argue that with those two since they were sucessful in big races with it?
Sure you can ... hell I always argue w/ them ... never works out well for me though but i do it anyway hahahaah.
Good example, Fairtrace has been on my ass about changing my body back to a Mazda or LTC for about 6 weeks now, and about 3 weeks ago he to a quick look at my diff made a face like he just ate a lemon whole and gave it back saying (i'm paraphrasing but you get the idea) "that is a bad case of s&^%ty diff, fix it, on asphalt your diff is super important"
What did i do ... take a wild guess hahaha. Didn't change the body and didn't fix the diff (i have a wife and kids so it's a little tough to get hobby time sometimes, at least that is what i tell people anyway) so yesterday i go to a big trophy race, car is all over the dam place cant get the car to hook up AT ALL i mean terrible. All my quals are in the toilet. Before the main I changed the body, rebuilt the diff (it had a blown center bearing) and ran times that would have put me at the bottom of the B main instead of the .... ZZZ main
Take it for what it's worth .. those guys know the car and know setup they can also drive really well.
On a side note, the racing last night was crazy and makes me want to head out to an IIC or something even just to watch!! You should check out the east coast Race of Champions thread in the racing section, the A-Main driver list had winners from IIC, Snowbirds and Reedy. The Type-R was right there in the mix .
YmeBP is offline
Old 07-20-2009, 08:57 AM
  #9896
jrxs-r's Avatar
Congratulations to Dragonfire for winning the ACT State Modified Title. This is one of the few carpet events in OZ and its was great to see the Type R triumph on this surface.
Congrats dude!! +1!
jrxs-r is offline
Old 07-20-2009, 10:31 AM
  #9897
Company Representative
SweepRacingUSA's Avatar
you were at Jackson last night? I thought you said you coming so I was looking for a car with that center shaft but didnt see no one, thought you didnt make it. did you pit inside or out in parking lot?
SweepRacingUSA is offline
Old 07-20-2009, 10:33 AM
  #9898
I would love to see someone of the likes of Mark.R. have a run with this chassis. It would be scary to see how fast it can go....
Does anyone know if the original JRX-S pulleys (white) fit the type R? That delrin looks more durable.
Old 07-20-2009, 10:49 AM
  #9899
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yes, same mold.
MikeXray is offline
Old 07-20-2009, 10:52 AM
  #9900
Originally Posted by MikeXray
Yes, same mold.
I thought JRXS pullies isasme with XXX-S ?
Mike how come no Jackson for you yesterday?
