Team Losi JRXS Type-R
#5356
Im a huge fan of the 9550 for conventional cars but if you can have more speed and power without sacrificing why not. I am running a JR 8800 servo right now. Its a little heavier than the 9550, which is good becasue a little more foreward weight in the car seems to help. Also its .03 faster and more powerful than the 9550.
#5357
does anybody having problem on the gearing? It seems this car can't use 3.5 brushless motor, it is way too hot. Unless I can install a larger spur. I already use the smallest pinion pushing the motor to the most right with 128T spur. I think I should use a spur adopter with something like 132 and file the chassis a bit. What do you think? And who makes the adopter for type R?
#5358
I've got my PT stuck to the back of my 9550 and wired inside, inline with the servo's power leads. I've been doing it for a month now with no noticeable loss of power to the servo, and without a single missed lap. I had a damaged plug on this PT that left the leads short, so it seemed like a good opportunity to test it. It definitely makes for a cleaner wiring layout. I'm not sure I'd do it at a big race though, just in case. :-)
#5359
Super Moderator
#5360
Im not a huge fan of the 9550, it was great for conventional cars but if you can have more speed and power without sacrificing why not. I am running a JR 8800 servo right now. Its a little heavier than the 9550, which is good becasue a little more foreward weight in the car seems to help. Also its .03 faster and more powerful than the 9550.
-Adam
#5361
I had a break through day today with my Type R. I was doing a lot of IMing with Schreff and I finally got my car sorted out. Jason gave me a setup to try but it turned out mainly to be a bad servo steering setup on my part when I put the car together originally. I was telling Jason how it reacted and he was telling me to try a few things when the light bulb went off in my head. I am not going into details since it was not the cars fault but the idiot that put it together, that be me. All I can say now is that I am fully enjoying this car for once. This car rocks and I can't wait to run the foam car in LV this year for now that I know how it works on asphalt, I really want to see how on rails it is for carpet, in my hands of course. Thanks again Schreff and I am sure you will be a great help at IIC this year also.
#5362
#5364
For me is was just not getting the servo centered right and actually using the link between the horn and steering rack as an adjustment also. It basically turned better one way then the other. The old car you could not use the link as an adjustment because it was solid. I plan on changing that later this week so I can get that car right as well. So with the servo really not being on center I was messing with EPA's to get it closer and it was just basically jacked up. I kept blaming the setups for the rear of the car not hooking up when all along it was just too much steering one way and not the other. I believe I also had a gear going bad as well in my servo for it did go out in my second qualifier so I had my wife run home and get my other Type R and took the servo out of it. It was even smoother with a fully functioning servo too. So I just now need to get the replacement plastic gear and my previous servo will be all good again. As I said, it was not a fault of the car but of the idiot that put it together.
#5365
#5366
The carpet setup development has been going extremely well. The setup will cost you.
#5368
I'l be at the iic as well.
#5369
all this servo talk has me thinking... i develped a "crunchy" spot in my servo (guess that servo saver was a bit tight), so i just rotate the horn one tooth and adjusted the turnbuckle to compensate. since then it seems like i'm always fiddling with the center point on the radio.
time to order new gears for my race servo and my spare and re-do the steering per the book.
