Checkpoint motor FAN fixation
What is the part used by Team Checkpoint drivers to fix the FAN on then Chekpoint Endbell.
Here is a pic of it on Olly Jefferies car at the worlds (the red part between motor enbell and FAN)
thanks a lot, so how to do the modification?
I see how to screw the FAN on the standoff but how to screw the standoff on the endbell?
use a 25mm fan.
to mount on endbell
I used 3x10mm or 12mm grub screw.
redrill and tap the mounting plates for 3mm screw.
after motor is reassembled. insert the grub screw
with about 4mm stickout for the standoffs to
screw on to. then install the fan.
or if you have a long enough 2.5mm screw
to go all the way through the fan and standoffs.
to mount on endbell
