New Novak Stock Brushless >
Old 02-14-2007, 04:53 PM
  #511
sepirts's Avatar
Originally Posted by Arboleda
PS - Any tips on pinion for an MF2 with a 13.5 / Orion 4800 combo?
I've run an MF2 with a 13.5 and Orion 4800. I usually start with my stock +2 teeth for pinion. I've gone as much as +4 teeth, if I'm on a large open track.
Stock being = 19-21, depending on your setup.
sepirts is offline
Old 02-14-2007, 05:41 PM
  #512
What do you guys used to check your motor temps?
The8BitHero is offline
Old 02-14-2007, 07:11 PM
  #513
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
http://www2.towerhobbies.com/cgi-bin...&I=LXEMG5&P=ML
Marcos.J is offline
Old 02-15-2007, 06:21 AM
  #514
Originally Posted by smojoe
two questions for the resident experts in this forum
1) is it okay to cut the sensor wires on the motors? I've heard a few rumors that pretty much end in two conclusions: "Go ahead and cut them" and "Don't cut them EVER."
2) do I need to use the GTB's supplied capacitor with the 13.5 motor? You know, the beer keg of a cap. I would like to use the small cap that is included with the LRP worlds kit, mostly because it is 1/20th the size and 12th scales don't have a lot of landscaping area for electronics.
You can cut the blue wire for the thermal sensor but I wouldn't recommend it. If you're getting hot enough to thermal you're getting close to hurting the motor. The rest of the sensor wires are needed.
In 4 cell you definitely need to have the capacitor on the speedo. There's plenty of room for it. I'm thinking about adding a second cap to help keep the speed control temp down.
I can fit the speedo, transcap, and a receiver pack in a L4 style car.
Unregistered is offline
Old 02-16-2007, 02:40 AM
  #515
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
I just tried my 13.5 with a sintered rotor from a standard rotor, it runs a LOT cooler, but also feels a lot slower! Do I have to gear up even to get comparable speed? Should it sound different as well?
nexxus is offline
Old 02-16-2007, 04:57 AM
  #516
SlamMan's Avatar
You do have to gear up when switching to the sintered rotor. People run anywhere between 36 and 42 mm roll out.
SlamMan is offline
Old 02-16-2007, 05:40 AM
  #517
I just started racing with the sintered rotor and I think I may be able to gear up as much as 3 teeth or more from the regular rotor. Been running the 13.5 since September with the regular rotor with no troubles. Except I finally burned up my LRP COMP.
Faster1 is offline
Old 02-16-2007, 05:55 AM
  #518
nexxus's Avatar
But should changing from a normal to sintered rotor, and leaving all other things the same, result in a speed drop which I need to gear up again to compensate for?
nexxus is offline
Old 02-16-2007, 08:02 AM
  #519
sepirts's Avatar
Gear up.
sepirts is offline
Old 02-16-2007, 08:10 AM
  #520
Yes, you have to gear up with the sintered rotor because it has less RPM. We're going as high as 2.5 rollout in 12th (or higher) but you have to play with the gear to get the best laptimes. I'm only using motor and speedo temps as a safety thing. The lap times drive my gearing (normally around 2.35 in 12th on carpet).
Old 02-17-2007, 06:21 AM
  #521
nexxus's Avatar
Have found that with the Sintered Rotor, I can't gear up the TA05 far enough, can only go to a 25 pinion and was running a 21 with the bonded rotor, to get the speed back I'd need to be around a 29-30 pinion which won't fit!
Back in with the Bonded Rotor
nexxus is offline
Old 02-17-2007, 06:34 AM
  #522
Super Moderator
Marcos.J's Avatar
how about dropping a few teeth on the spur??
Marcos.J is offline
Old 02-17-2007, 06:54 AM
  #523
RocketRacer's Avatar
@Nexus - change the 48dp standard spur in the car to the 64dp 105T spur that is available for the TA05. that will give you the gearing you want. hope it helps!
RocketRacer is offline
Old 02-17-2007, 07:31 PM
  #524
hierog's Avatar
nvm, i got it figured out now!!
hierog is offline
Old 03-13-2007, 03:33 PM
  #525
Capelracer's Avatar
I've seen the announcement that in April, you will be able to buy a "Pro" version of the 13.5 / GTB combo which means that the sintered rotor is already present.
I saw a post on another forum (but then lost track of where I found it) that someone has already been able to purchase the 13.5 Pro motor (not the system with the ESC, just the motor). But a search online did not turn this up and any online vendors. Is the 13.5 Pro motor available for purchase or must one buy the sintered upgrade separate? Thanks!
Just got 1 from Pacific Coast hobbies - still in the old packet (even says neodyninium (whatever) magnets, but is the real deal w/- ribbed can, sintered rotor, orange ring!
Capelracer is offline
