Best rubber tire
#31
Originally Posted by AdrianM
The nylon rims are also 1-2/10ths per lap faster than the old rims
#32
I like RP30-s but as Adrian stated the rims break like glass...
How can I make sure that the set I buy at my LHS has the new nylon type rims?
#33
I wonder why no one has mentioned lrp (Vtec) tires?
Here in europe they become more and more popular and somehow i prefere them better than cs tires
#34
I've never heard of those. In the states, most racers use cs, rp, and sorex tires. I've been using medial pro premounts and they're really loose even with me using blue front/rear green springs with shocks layed down. Same setup with sorex and the car just wouldn't turn.
#35
#36
#37
Thanks Adrian, I've bought a set of CS27 the other day and yes it is easy to tell the difference. They are NICE...
#38
#39
Hi Guys, How does the tweak2000 compare to other additives? what would you advise for what heats etc?
Ricky
Ricky
#41
Who is dip made by? and are you still using the warmers with this.
Anyone else tried any others or this one?
Ricky
Ricky
#42
schumacher imports it.you can contact Adrian M if you want to purchase some.i do use the warmers with both.there is something about the dip that works better on the rp tires.you wont regret trying it.when i use tire tweak on the take off tires, i bake it in with the tire warmers and take it off with buggy grip right before i race.works really well
#44
i use motor spray on a rag to clean the tires right before i add the traction additive.my reason for using the warmers is to open the pores in the rubber and allow the traction additive to really get to the tire.it also gets the tires pre warmed up so it doesnt take 2 or 3 laps for the tires to get good.they are good as soon as they hit the track.
#45
What insert are people using when running a sorex 28 on carpet.
Also if anyone has a tyre/insert combination they suggest it would be great!
