Originally Posted by Charles Yates
(Post 16253731)
where can you find their tires?
Originally Posted by Racer311
(Post 16253747)
This is what I’ve been recommended to get for racing in Vancouver.
I was advised to go for the D36 ones which I think are the following - D36 D-SPEC Asphalt TC tire 4pc set Pre-glued.Can you confirm these would be the ones? Seems like they only come with the thick soft inserts, so I guess that’s what I’m going with. Also, how many races/race days are they lasting you? thanks |
Originally Posted by gigaplex
(Post 16253772)
It's possible to get those on various rims and with various inserts.
Anyone have experience with the Takashima D-13 vs Wei RC steel chassis on black carpet?
Originally Posted by PROMODVETTE
(Post 16254668)
The machine work and finish on the Takashima is better however. |
Was there any improvement over the stock aluminum chassis?
I'm mostly looking at it due to weight and keeping the CG a little lower. 100g of W all over the chassis is no fun. |
(Post 16255394)
I'm mostly looking at it due to weight and keeping the CG a little lower. 100g of W all over the chassis is no fun. And yes it's nice not having all that extra weight stuck everywhere. |
Hello. Just got the kit. Are you guys CA gluing the edges of the carbon parts ? Example the lower arms? Thanks
Originally Posted by WashedUp
(Post 16255500)
It has its weak points but tends to flex a bit more before finally breaking. There's arms out there with more bracing also helping give the car a more direct feel on high bite tracks. |
Originally Posted by Robbob
(Post 16255501)
Nah, kit is pretty strong material.
Shock upper ball
Part number A2557 - Upper Shock Ball.
As a first time builder, can I ask, how does this fit through the shock cap hole? it seems almost too small and I’m not sure how rough I should be? Any tips or tools I should use for this. Thanks |
Can't go wrong with either. Kit would be more cost effective.
Originally Posted by rccartips
(Post 16255929)
it seems super tight and not sure how rough I should be? thanks |
Make sure you are going in the right direction, it goes in one way but not both ways! Push in opposite side of the hole. It is going to be a little tight, but it does snap it and move mostly free once it pops.
| All times are GMT -7. It is currently 06:57 AM. |
