Schumacher MI9
#272
Grindog001, If I were in your situation I would get the Mi9 carbon version and then get the Schumacher alloy chassis (U8645). This way you can try both on carpet or tarmac. krazedbuilds makes very good products but I would not start out with a new car running a chassis from another manufacturer. I would want to see how the car works as designed first before I start changing things up.
#274
I was just wondering if anyone has run the carbon on carpet. I know it's not going to be as good, but hopefully it could provide an ok starting point for both surfaces. I don't really want to change the chassis over each week, I was just curious if anyone had tried it.
#275
Super Moderator
#276
[QUOTE=Marcos.J;16102051]KrazedBuilds has the alloy chassis
[/QUOTE
Is this chassis supposed to be better or just a replacement?]
[/QUOTE
#281
dawgmeat, yep I ended up adding weight under both the front spool and the rear diff outdrives....we'll see how that works. I feel like it's going to throw the handling of the car off but we'll see.. What confuses me is that if you look at all the setups from the Schumacher team they don't even really talk about where weight is located. Having to add 100g I would think should be a big deal and mentioned by the fast guys. Test day today so I can work on that..
#282
Putting my car on balancing pins I found I had to add most of the weight under my receiver. Right behind my servo. Also added more weight under the rear diff outdrives. 10 grams on each side using the AMX round weights. Came in around 1330 total weight of car.
#283
There is some weight information on the sheets, but it also depends on the electronics and bodyshell.
On my mod car I went with 49F/51R weight distribution and 50/50 left right. I added 95 gram to get to 1300
2x 5 grams screw weight in front of servo and battery
10 grams next to the servo (centerline)
33 grams battery weight
22 grams under the receiver
20 grams next to the esc under the belt (centerline)
I always try to add weight to the centerline, so for my stock car I ordered some tungsten weights so I can use the same positions and probably add some more in front of the servo to get 50F/50R balance.
#284
First race with the new Mi9. Came from running an MTC2. Car worked great with the tarmac setup. As the day went on the car got better. The car was light so had to add weight under receiver and rear diff outdrives.
#285
