Bumpstops for Touring Cars?
#77
#78
I can see the benefit in a soft bump stop (one that has noticeable compression) in certain track conditions. Think of it more as a 2-stage spring, kind of like the Awesomatix PSS setup.
I don't think a near-solid bump stop would be beneficial though. Touring cars don't seem to like sudden violent loading like that would provide.
#79
Test and Tune was yesterday and I decided to keep the bumpstops in. The shocks have about a 3mm stroke now and that's all I need. it's allowing the car to corner flat, generating an insane level of grip in the corners. I don't have to wait for the car to get settled at the corner exit; I can get on the power instantly. I also have much less squat and dive aswell.
In two weeks, we'll have our inaugural indoor race and it'll be good to compare times from last years end of season race.
Stiff is good!
Stiff is good!
#80
I guess the bumpstops also act as a heave damper when the suspension is fully compressed...
#81
RaceOpt T3M v2 has built in bump stops.
#83
The Evicerator
Foam above the bladders may provide some sort of residual bump stop type action, but in my view they primarily are there to slow/prevent the colapse of the bladder under high speed compression...
In my experience the best place for bumpstops on a traditional car is on the outside of the shock body on the shaft ...
Different materials will yeild different results... hardness of the material and total travel reduction seem to factor most heavily
#84
I have been looking around a bunch for suitable materials to use as bumpstops, so far the best option I have found are these soft silicone grommets, will have to order some and try them out:
They are 3.5mm inner diameter and 6mm outer diameter and a nice base to fit on the lower spring retainer.
I'm wondering what other materials people have found that are ready to use as bumpstops, and where you bought them?
Cheers
Cheers
#85
Cheers
Cheers
#86
Nice grommets....
#88
Think of it this way .... less roll = less weight shifted in that direction.
Increasing the point load would cause the tire to breach its limit.
Its more technical then that but thats a simple way to think of it.
Similar to progressive springs on the front. Soft to let it steer then compression causes it to stiffen up and create a push.
IMO bump stops would be a rabbit hole of tuning.
RaceOpt system intrigues me but not enough to keep tearing open my shocks lol.
#90
O rings washers yellow gas fuel tubing ear plugs.
I have noticed guys using Orings and such for 20 plus years. I started racing at a dirt oval track and decided to use bump stops on my cars. With limited space on shaft I did even use ear plugs inside shock too. It definitely helps. I just added some to my 25.5 tc. Not sure it's nessasry? But why not. I have decided it's never good for car to contact track.
