1/10 chassis that takes Lola Body (mini 1/8)
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
It has been at least 15 years since I have had any place to even start or run my 1/8 on-road nitro cars.
For many years I had wanted a similar car with electric power, and rubber tires. I tried converting one of my old Serpent Impact 235mm cars to electric but could not find all the parts. Even then, with the foam tires, I'd have no place to run the car.
I only recently discovered the Serpent 750e. I know they are selling it for drag racing (of which I have no interest).
Question: Are there other 1/10 cars besides the Serpent 750e that are designed for the Lola body, rather than touring car body? (220 or 200mm?)
This is my Serpent that has become a vintage shelf queen due to no place to run.
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/676x768/serpent_950_61b2986df12947254f0854021f69733cd7e5d2d3.jpg)
This is the Serpent 750e 200mm car. This is what I want to build with rubber tires just for fun, there are many parking lots near me where I could run it. Is Serpent the only maker of a 200mm electric car like this?
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/1280x960/60119_83040_1620176595_fa959598f5b49979abb096dbfd9f9e418908e507.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/900x520/serpent_natrix_750e_4wd_110_ep_1_dafc4f26abb5fb09cb5405eb40410e62fdc63f39.jpg)
I found these HPI wheels that I think would look good. They look kind of like the 1/8 foam wheels I used to run on the Serpent 950 years ago.
![](https://cimg1.ibsrv.net/gimg/www.rctech.net-vbulletin/1756x1446/screen_shot_2022_03_11_at_10_52_08_pm_691bfdea6f789b8c17d1a1d5c87715c7a0532a78.png)
This is my Serpent 835; 4-wheel drive 235mm 0.15ci. Only saw 3 races in 2004 and never run since. I'm glad I did not electrify it as it is somewhat of a collectors item now Serpent is not made in Netherland.
Correct me if I'm wrong but no one ever made an electric 235mm class car, correct?
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1325/serpent_835_363b02f552677e9e82fce73d63bf154ddcfeeff9.jpg)
While there are electric 235mm pan cars still around (or again, depending on where you are located), they are quite a bit different from nitro cars. Being 2WD only, different suspension, being much lighter, etc. You can look them up here: Pro 10: 235mm Le Mans Prototype Pan Car Discussion
Cannot promise that these cars will actually fit this exact body, or if they are really what you're looking for.
The Serpent is a 200mm touring chassis. There are some 200mm tourers arround, I believe the HPI sprint is also a 200mm
Otherwise you can always get a 190mm electric touring chassis and use some offset wheels or hex adapters to get close to the 200mm but a pro-10 has for sure much better looking bodies.
EP:1/10 E.2 220mm Espirit X1 ARR Chassis Only Lola Edition - EDAM-your best choice for RC cars!
take a look at this chassis
That is great. Thanks for the link! Seems to be about half the price of the Serpent.
Looking at my picture of the old 835, I think it needs a good re-build and cleaning, like I did to my old Kyosho:
Kyosho Landmax 1999; Restoration
I can only see two alternatives to the 750 and its ridiculous mass repartition:
- Edam E-spirit, in the lola configuration (about 220mm)
- Xpress DR1S (about 200mm)
