GT12-RT
#871
I'm new to foam tires... what is the best foam type for black carpet. K Foam, T Foam, shore hardness?
#872
You are better served by reading the Wiki at the top of this forum - 1/12 forum
IT has quite a bit of tire information already posted, and specific information relevant to Black carpet.
#873
Perfect, thanks for the info "simple"
#874
Question on batteries....
For example, looking at the Trinity website they have:
White Carbon: (LiPO)
7400mah 135C 3.7v 1S pack
8000mah 130C 3.7v 1S pack
RevTech: (LiHV)
8600mah 140C 3.8v 1S pack
What's the preferred battery in 12th scale racing? In this class most folks run the USGT fixed-timing motor. Other classes they run whatever from 21.5 to 13.5 to Mod. I'd imagine most places tech batteries to 4.2v per cell so whether running 1S or 2S packs, you'd have to charge the packs to the required "tech" voltage. So not sure if charging a 3.8v LiHV pack makes any sense to only 4.2v instead of 4.35v. Curious if anyone has done any testing on this?
RevTech: (LiHV)
#876
A chaotic Main from Wednesday. Short on marshals and a 10 lap difference from first to last
https://youtu.be/wJoAis356LI
#879
My charger only goes to 14 amp and I never used a heater for my batteries. I've never felt comfortable with those high charge rates, even back in the old nicad days. Once you see a couple packs go up in flames it kinda teaches you to play it safe.
Regarding the heater pads. Has anyone really seen an improvement using one in 21.5 rubber tire? There is so little power to work with anyways, I wouldn't think they offer much improvement.
#880
R/C Tech Elite Member
#882
Charge at 2C max (8 amps if 4000mAh). Storing in the fridge is now unnecessary. The better way of doing it is to keep them at room temperature and make sure they're not in a hot environment. IR is now your yardstick. Good cells should be under 5 milliohms per. If they start rising to 6 or above, then consider replacing the cells. 10 or higher means the cells now have degraded and that's when you should retire the pack.
#884
It just doesn't make any sense. It has some aditional risks (for the batteries and for your health if you're using the kitchen fridge) and for a regular person this practice brings absolutely 0 benefits.
#885
Interesting side though. Our track has handout batteries for GT12. You get one for the day. These things are routinely charged at 30A and heated. I don't think any have puffed. After a year a couple of them were weeded out due to IR's that were over 2. Different brand and probably a different cell maker.
