Roche Rapide P12 Evo2 1/12th Competition Kit >
Like Tree187Likes
Old 11-04-2021, 06:41 AM
  #76
https://www.redrc.net/2021/11/roche-...r/#more-201580
RacinJ, No9 and gwc like this.
DavidNERODease is offline
Old 11-04-2021, 07:13 AM
  #77
gwc
Looks like a three position caster setting...nice!
gwc is offline
Old 11-04-2021, 07:20 AM
  #78
gwc
Originally Posted by DavidNERODease
How will the battery be held in...tape?
gwc is offline
Old 11-04-2021, 08:15 AM
  #79
Not sure - I initially thought tape but not confirmed.
gwc likes this.
Old 11-04-2021, 08:17 AM
  #80
It's 5 actually - one extra step at each end with out the little position screw.
gwc likes this.
Old 11-04-2021, 08:20 AM
  #81
More details of Rapide P12 EVO2, Fully Fine Adjustable Front Suspension.
- Caster : 3/4/5/6/7 degree selectable.
- Reactive Caster : 0-5 degree fine adjustable.
- Roll Center : adjustable long or short upper arm by lower bulkhead in different direction.
- New upper arm with body upstop.
- New aluminium offset pivot ball holder.
- New single piece lightweight steering knuckle with axle.
- New spring steel kingpin.
- New graphite lower arm.
gwc likes this.
Old 11-04-2021, 08:56 AM
  #82
gwc
Even better!
gwc is offline
Old 11-04-2021, 11:09 AM
  #83
Not sure that I understand the need for a body up stop screw.
MC Hamilton is offline
Old 11-04-2021, 11:30 AM
  #84
All cars can benefit I think - especially on CRC black carpet where bodies often have to be run much higher than say on old CRC grey Ozite.
gwc likes this.
Old 11-04-2021, 11:35 AM
  #85
... the stop allows the body to be run lower without touching down on the racing surface when the car rolls/leans in the corner. The stop will push the body up when cornering.
Old 11-04-2021, 11:52 AM
  #86
gwc
True, they work great on my Xray T4 20 so it should do the same for 1/12th.
gwc is offline
Old 11-05-2021, 12:25 PM
  #87
RocheRCUSA's Avatar
First order for RocheRC USA has arrived. We are matching the inventory to back orders and will post an update if there are any unspoken for
RocheRCUSA is offline
Old 11-05-2021, 01:52 PM
  #88
gwc
It is a tape in battery setup, guess that is due to the new chassis design.
pictures...https://site.petitrc.com/reglages/ro...dep12/P12Evo2/
DavidNERODease likes this.
gwc is offline
Old 11-06-2021, 09:13 PM
  #89
Very interesting what they did with the upper pivot ball design. It aluminum (not plastic) and the damping is applied within the upper pivot ball assembly - not on the kingpin. The steering block pivots on the kingpin and isn't affected by the damping fluid in the upper pivot ball assembly.
Old 11-09-2021, 06:40 AM
  #90
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
Manual is posted up on Roche!
http://www.rocherc.com/manuals/P12%20EVO2%20manual.pdf
Looks so good!
ChrisP likes this.
Mr. McGoo is offline
