Xray X4
#1366
For me it settles that the perpendicular position is the closest but not the right one. From what I understand the two lines should be superposed, so it means that the ideal position is close to the perpendicular but should be found using the "secret symmetrical steering search" (ensuring that steering angles are identical left and right when EPA is equal).
Am I wrong?
Am I wrong?
As soon as you go down in D/R though, due to the non-overlapping ab... curves, then you will need to readjust the steering link (and hence angle) a bit...
do you agree?
#1367
Am I wrong?
Am I wrong?
#1368
So making what I describe is useless? or it is 1% worth?
#1369
not useless for sure, but not sure if worth the effort, at least during a busy raceday. When prepping the car on the bench, that's another story of course!!!
let's talk saturday at the track so we are on the same page! I think I've nailed it during the winter races this time but I want to run it through you first
a+
Paul
a+
Paul
#1370
Can anyone give me some insight on what will happen when a new version of the X4 is due. I'm new enough to Xray, and just curious. Will there be a total redesign for '23 or is it going to be a situation where there are minor changes, and will simply be releasing parts to keep the car up to date?
I realize none of us know the answer to this, and it will be all speculation, but i've been running awesomatix, and xray periodically, and am trying to drill down on what I want to keep as my permanent ride.
Obviously both companies have their plusses and minuses, and while both appeal to me, I do like the fact that i know that the awesomatix will likely have minor upgrades to the current car, and with xray there is likely going to be an urge to purchase new once a year.
Is there any word if that is going to continue to be the xray model, or now that the X4 is here, will upgrades become more minimal, and will they be giving us the option to bolt on new parts as they are improved upon instead of starting from scratch once a year?
#1371
As you said, nobody knows for sure, but I think it's most probable that Xray will update their new platform, the X4, just as they did their previous platform, the T4, i.e. incrementally, not drastically. Except that they will probably again change both chassis and motorplate, just to make it expensive enough that no one can (reasonably) just upgrade and will buy the new kit instead. Oh and the new kit will traditionally come this fall.
#1372
#1373
R/C Tech Elite Member
Finally started putting my X4 together for the upcoming summer asphalt season. Have to say its going together nicely. The ball fit in the new carbon arms is downright sexy. TOTALLY smooth. I used the 17mm alignment jig for the bulkheads but I don’t think it was even necessary. Well done Xray.
#1374
In hindsight, I think the 20-21 line was really a gap filler while the team was working on the "new-standard" car - the MM and longer arms were probably easier to release to market quicker.
we should still expect an x4 '23 sometime this fall
#1375
The ‘23 will be a ‘22 with V2 parts standard and some other insignificant changes. Look for something slightly more significant in ‘24 (like non-circlip hexes or slightly larger shocks (Thanks AE - *sarcasm). If you see a deal on a used ‘22 best grab it. I suspect the price of the ‘23 will be significantly higher (like everything else right now).
#1376
In retrospect I'd call the change from 19 to 20, which I previously considered big as well, as only medium. It still was the T4 platform with many parts still common between them. Yes, they changed to mid-motor, and longer suspension (although you could still use the older parts for the latter), but at the core, it still was the same car. They X4 was a major shift, and while it created some controversy, it's seems to perform quite well, and not even Xray can afford to throw that out of the window and start anew once again, so I think it's pretty safe - IMO at least - that there will not be another major large scale change this fall.
#1377
ARENA Option Parts for X4 upper arm
#1378
To those who have tried this trick ... which type of brake cleaner did you use? Regular, Non-Chlorinated, Reduced VOC?
#1379
hi guys,
I sold all my equipment in 19 and had a 19 T4 back then. Now i'm thinking about coming back to the game , how do you guys like this out the box? does it take a lot of setup to make it work? I'm thinking this or the Mugen. (dont flame me lol) I miss onroad but there really isn't an onroad scene here in Florida anymore which is disappointing.
#1380
Super Moderator
hi guys,
