Old 12-20-2002, 12:07 PM   #16
Cole Trickle's Avatar
Default Re: Lowering a Chassis
Originally posted by popsracer
Cole;
If you lower your ride height by changing spring preload (the correct way) then your Droop will increase by the same amount. Just something to take into consideration.
I'm using the preload to adjust the ride hight. But my car have droop screws, so my droop will be decreased, as far as I can see.
Anyway, thanks for all your input, I didnt expected so many replys.
Plans was changed last night, so I didnt make any experiments. But I think I'll try to lower my ride hight sometime, when I got good time for experimenting. I believe I have to try it out, to know how it will effect on handling.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-20-2002, 03:59 PM   #17
popsracer's Avatar
Cole Trickle;
Didn't quite understand your last post about droop screws. If your car has screws for the droop adjustment then just use the screws to reset your droop after lowering the car. Otherwise shock length will have to be adjusted in someway to keep the same droop settings.
popsracer is offline   Reply With Quote
Old 12-22-2002, 06:17 AM   #18
Cole Trickle;
My last post was confusing, since I mixed it up. Of course, the cure is simply to re-adjust droop, after lowering the car.
And you're right, if I lower my car by 1 mm, the droop will increase by 1 mm.
WTB: JR Z3650, setup board, ride hight, droop gauges, tweek station espresso1967 R/C Items: Wanted to Buy 2 06-03-2008 06:38 PM
Mugen ride hight/droop gauge bcclothing R/C Items: Wanted to Buy 0 12-16-2007 11:41 PM
Integy set up station and yokomo droop and ride hight gage saleen95 R/C Items: For Sale/Trade 13 11-01-2007 01:03 PM
Help w/mtx4 ride hight saul Nitro On-Road 7 10-30-2006 06:16 AM
