XPRESS Execute XQ2S
#481
Anyone else having issues getting the rear ride height low enough? With 67mm foam tires and collars maxed out I'm sitting at about 7-8mm, would like to get it down to 5. At the front I have a few millimetres of threads left to play with at 5mm RH. Built according to the manual to the best of my ability, can't see where I could've gone wrong.
#483
True the foam tires down to 63mm to get to 5mm rideheight...
#484
I have 2 of these kits. Both has had the XP-10740 fail. It is the Composite Steering Post. The aluminum replacement is XP-10494 and I have that on one of my kits. When I went to get another one, noone had them in stock anywhere so I guess everyone has the same problem. I found a perfect replacement. It is XP-10705. It is the Aluminum Steering Post for the Arrow AT1 and it fits perfect.
#485
#487
When are we getting an XQ3S based off the XQ11?
#489
Anyone know where to get the XP-10365 (6mm wheel hexes) OR have an extra set they wouldn't mind unloading? Having an issue with the Gravity belted USGT wheels rubbing the little set screw nub on the lower arm. Using 6mm Yeah Racing hexes right now which prevents the rubbing BUT I wanna race this in a box stock class at a local track and don't wanna get called for using illegal parts (Grav belteds are also the only tire used for the class i'll be running).
#490
#492
what kits are yu guys using to rebuild the shocks?
looking for part XP-10115 ALUMINUM ONE PIECE LOWER BULKHEAD, does any one know where i can get a pair of these?
#493
I enjoyed using the Xq2s. I'm interested in the release news for Xq3s and I'm curious what changes there are.
Although I am using the A800R, I am still interested in the entry-level model, and my main body of interest is the successor to the XQ3S and Cero Sports.
#494
Does anyone know if the XQ2S and AT1S body mounts are in the same location?
#495
