Touring by h2e (1/10th, 190mm, 4wd)
#586
I think one of the missing items here with the mention of the suspension body limit screws, this is adding to unstrung mass in cornering technically, but it is also putting the downforce of the body directly on the hub. The handling effects of having these set correctly are pretty noticeable....
Zack
#587
LOL - Honestly I dont care about the weight of the screws but about the weight of the body that is right on top of these screws :-)
#588
But to simply have heavy un sprung weight without the benefit of lowering body cg or aero downforce most likely hinders performance.
On the rear I do wonder why 1/8 have the body as part of sprung weight (e.g. direct downforce), while on 1/10 touring it is not designed that way.
#589
The time immortal trade off between aero (or lower body cg) and mechanical grip. I've seen paid driver run front lip 1.5mm off the ground (the body is touching these post on resting ride height). But I think in the original setup there was free play and body weight is not part of un sprung until suspension reaches extreme compression.
Might we worth putting some posts on those rear arms and see you can get enough steering out of it.....
Zack
#590
I think it is important to try to minimize unsprung weight when you can. However freely moving drivetrain and adjustability are a nice thing to have.
Zack
Zack
#591
In my measurements, the MTC2 was 5grams heavier in un sprung weight per each of the rear suspension components and 2grams heavier at each front compared to an Xray T4 2018 hinge pin design. That alone would be a big disadvantage in traction and handling.
The MTC2R, with addition of ball bearing CVDs probably made it even worse in terms of un sprung weight.
Tamiya's are bad in terms of slop which hurts traction and precision driving feel. We can shim the slop out of a Tamiya but it comes back after 1 run.
#592
Infinity and Axon still run hinge pins at the wheel hubs/knuckles and single turnbuckle camber links.
Big on road race will be in 3 weeks. A rare event where Xray, Awesomatix, Mugen, Infinity, Axon, Yokomo, Tamiya, Xpress, ARC, IRIS send their factory drivers to battle it out. May the best design and driver win.
TITC
Even Atsushi Hara will race
#593
#594
For 1/8 cars the entire reason for the floating rear body mount is not downforce, but to simply keep the body from dragging as the tires wear down. Longer nitro mains will see tires lose 7-9mm of diameter in the rear. The body would be on the ground if they didn't use the floating mounts.
Even the drag guy have gone to floating mounts as a way to transfer downforce into rear traction.
If what you were saying was the reason then why dont they have the same setup on the fronts?
#595
Is it to allow longer arms and more stable roll center movement during roll?
TITC
TITC
As for longer arms, they allow for more resolution through the motion. It's the same concept of playing with different servohorn lengths. It's also affects other things like the roll center adjustment range. I know everyone recommends the ryan book but I recommend reading adrian's newey's book how to build. It has very good fundamental info formation to gain more knowledge of what affects a car. Granted it's for full sized cars but the fundamentals still apply for a model car.
BTW, tc do have that 1/8 floating mount system but on the front. Only difference we arent worried about tire wear so stops are designed more for stabilizing the aero platform. If you have your body stops set correctly, the weight of the body should only be resting on the stop are the end of suspension travel. Yes it make a differences having the stops set properly.
#596
Well so far I can state that a well-designed hinge pin suspension can give many of the points mentioned above.
- sufficient roll center adjustability (long arms (65mm lower length), also inner hinge heights (Inserts, 7mm+/-1mm height))
- more robustness and less sources of failure in hard crashes
At least that's what I've experienced with my design. Comparing it to a full ball design (Schumacher Mi8), I have less parts coming loose after crashes. Pivots you might be able to re-tighten - but ripping out screws from chassis plates is unseen in hinge-pin design.
#597
As for the screws pulling through the chassis, I have a theory it's not an issue of not having enough material there, but rather that screws loosens every slightly and it starts eating away at the hole till event it gives from a decent whack. Another thing to keep in mind with hinge designs, You will develop more slope over time because the composite parts will wear out at a higher rate than a metal pivot ball. At the end, it's all personal preferences at the end.
#598
I've seen a world champ set his differently, body is resting on the stops at static ride height in order to have the front lip 1.5mm off the ground constantly.
#599
I've done that before but I don't drive clean enough to not miss up a spliter on a curb. I recently tried Hagberg method of setting the body stops and had no issues nor did I feel like I was leaving lap time on the table.
#600
Drag racers run them thinking they generate downforce. In reality it's for the same purpose, to keep the body off the ground when the car launches and to keep the tires off the body at the top end when they grow from the speed. With all the traction goo they run, they don't need downforce, in face they want as little as possible to avoid excess drag.
