LRP SPHERE COMP. ESC (80700)
#571
#574
#576
That's why I added the second sentence to advise you. Wasn't an issue with the LRP I got from them; but, it was a major pain with another brand item that failed on me.
#577
Trader Rating: 23 (100%+)
OK maybe someone has seen this
So I sent in my ESC and they being Associated returned it. It is a 2007 Sphere comp. It ran fine and checked out for htem and then ran 2 good qualifiers and then stopped. What it is doing is after you pull trigger randomly it will stop and the red/yellow lights come on as you pull trigger and it will not enguage the motor brand new 6.5 x-11 untill I rotate the spur and poof will work again until it locks up. So has anyone seen this and what is the issue, because I don't want to sent it back if there is nothing wrong. I am running a m-11 with spektrum a x-11 6.5 turn motor a cap in the esc and the sphere comp. It is very wierd.
-James
-James
#578
-James
-James
Your motor would be the first thing to rule out ..
switch it out with another first....
#579
-James
-James
#580
meltdown
Has anybody had problems with a motor and speedo melting down at the same time?
#581
have not seen that yet ...
Esc`s ?
yes...
never seen a melted brushless motor , its usually rotor, bearing`s or sensor...
Esc`s ?
yes...
#582
burnt up
The windings were touching the rotor between the magnets And the speedo all the lights come on but with a new motor it will turn slow then stop.Looks like i will be going to novak.
#583
guys, beside e profile diff between sphere and istc ed. wat are e other main diff?
#584
Guys on the LRP sphere TC
FET servo wire, can I cut it off? with no problems? I have no intestion at all to use a different servo then my futaba s9550... So I dont need a fet wire
Will the TC sphere with a novak motor thermal the motor? Will the TC thermal a LRP x-11 13.5?
#585
Super Moderator
