Team Associated TC5
lets see
Does anyone know if the new TC6 plastic arm mounts (now 0-3 vs 1-3 in the TC5 set) are form/fit/function replacements for the TC5 part number?
yes, the 0 mounts fit, but there is no room for the droop screws to do anything
Will a new TC6 '0' mount fit in the TC5 'A' mount hole on the bulkhead?
yes it does
How about the new front bumper assembly, will it bolt directly up to the TC5?
no it doesnt, the new bulkheads are narrower buy a weeee bit
ed
yes it does
ed
***FOR SALE***TC-5R CHASSIS & TOP DECK**
I have a brand new chassis (opened but never used), a brand new top deck (unopened) and a used chassis.
I'll sell it all for $75.
Alright, I'm very confused and starting to get pretty annoyed here. I'm breaking those stupid plastic CVA bone blades, at least one a night. The weird part is that it's ALWAYS the one on the left rear that breaks. The drive cup was slightly dinged up, so I replaced it. The CVA bone itself looks fine, so what gives? Anyone have this problem before?
Is your axle shaft running true? Are your diffs mounted at an extreme? Really low or really high so the axles are running at more of an angle than stock.
The shaft seems to be fine.. and the diffs are mounted at the kit setting. I think I'm gonna swap axles left to right though and see what happens..
I had the same problem. Even with new outdrives.
Maybe you could use the X-Ray blades or you try the TC6 blades. I have the feeling that they are made of the hard plastic. Until now I had no problem with the blades on my TC6.
For my TC5 I had enough after some weeks and switched to TitaniumRacing parts. Then the problems were gone...
Heh ....
My tc5 is almost 3y, newer change "broken" plastic blade at rear dog bone ...
At front when I put solid axle form AE, yes, it happen at each front tire hit ..
Check bearings, axle (maybe is binding when put new plastic), check
diff outdrives ...
It's really strange ... something is broken/bent and you must find it.
m
diff outdrives ...
m
Steering servo
I'm looking for recommendations for a steering servo, make/model, to use on a TC4 and TC5.
thanks
thanks
Some servos can't work with simple am systems.
But if have good radio, try use:
- futaba S9551 or BLS551,
- ko-propo pds-2413,
- savox is OK with lower price then two servos above.
About servos IMHO S9551 is the best choice that I made.
m.
Camber link part #
Does anyone know the part # for the front camber link tie rod. Is it #1401 1.30" or #1414 1.25". http://www.teamassociated.com/pdf/ca..._tc5f_tc5r.pdf Thanks
evreybody i know that has a tc5...complain about the corner speed....my question is....is it the car or is it the setup on the car??....but they love the way the car handles.......i was looking into getting 1....thanks!!
What is a good starting point for gearing of a TC5, will be racing on a mid sized carpet track, rubber tires, Novak 17.5 motor with no timing advance running a 2c LIPO, also 48 pitch gears.
messing about with the new tc6 steering bellcrank
i found i could fit it to a tc5 by just changung the centre post to the tc5 one
and the tc5 ball cups fit perfect to a tc5 too
Maybe covered already.. I am installing 4 degree Integy caster blocks on my TC5. It seems that the blocks hit the a-arms causing positive camber?? What gives? Anyone else run into this?
With the LRP X11 17,5t I start with 4,5 to 5,0. If you have the feeling of beeing to slow on the straight and the motor temperature is still OK you can go below that.
