Team Associated TC5
any idea on what set-up was ran on the tc5 at the EURO's ? car looked good in the videos. also are there any new parts in the works for the tc5? like factory modded bulkheads ? or anything ? just curious i just recently got a tc5 .
the pics on red rc show he ran exotek chassis and the modded rear bulk heads setup wise i have no idea.
Page 722 on this TC5 thread has some info. The mod starts a page or two before and continues a page or two after. Rick said using a RC8 servo horn gives the same feel:
http://www.rctech.net/forum/electric...d-tc5-722.html
Hi
I need some help with my gear ratio. Im running a Losi 3.5t system on 2s lipo. What gear ratio do you guys recommend?
Erik
Erik
Hey guys
hey i'm just curious what is the big difference between the tc5 and the tc5r.
I know I can pick up a tc5 cheap( yes cheap) but was thinking on holding out for a tc5r. or if it not much difference. i might just pick up the tc5 and get the exoctek chassas .
So any info would be great
Hey guys
Hey guys
So if you pick up the TC5 and the Exotek chassis then you would have specs similar to the TC5R
Best Regards
Robert
http://www.rctech.net/forum/6838360-post11707.html
Regards!
m.
Hey, I was wondering if this is worth while to get, I've never been a big fan of the kit plastic one as it seems easy to pull plastic through causing the spur gear not to sit flush.
This is the best money you can spend. All the problems caused by the unstable plastic one are gone. Since I switch to this one and robinson spurs I have never have a gearing problem anymore
Lot of pages ago I post pdf file with Christer setup
Regards!
m.
Regards!
m.
does anyone know where to get the shocktower mounts that christer anderson uses with the vertical ballstud mount?
Rick H- i saw on page 272 or something that you said AE is considering your modded factory motor mount and bulkhead for release. is this still being considered?
