Team Associated TC5
#6438
#6439
hey everyone
i just recently went from a one way to a spool and i need help with set up ideas. have trouble wit understeer at the start of teh corner then oversteer wen i put the power down. was thinking maybe removing front sway bar n straighting up the suspension on the rear? might even change the gearing to slow it down out of the corners to stop power on oversteer? am i on the heading in the right direction with my ideas? i race stock, rubber on asphalt
thanks
thanks
#6440
Finished my TC5R over the weekend and all the updates worked out really nice.
#6445
And in my TC5 i'm using a Nosram Prototype ESC, with an High Velocity 19T spec motor (my training car).
I did the following thing. My Layshaft holders of my TC5 are sanded a bit, so the free up the layshaft. When I was building my TC5R I took them out of my TC5 and replaced them at my TC5R. But after that I sanded the new layshaft holders and put them back in my TC5. Then i didn't hat to change my gearing so the layshaft is at the same hieght with my new layshaft holders.
Before I replaced them I put them next to each other and measured them. There was no difference. So I'm for sure they are not in my kit but if that's standart....
No problem Treemagnet!
Yesterday I wanted to try the TC5R for the first time, but it was raining cat's and dog's. So... I was just having a good time at the race track without driving :P.
Greetings Robert Krens
#6446
Trader Rating: 27 (100%+)
hey robert k do you think that you can post a good baseline rubber tire asphalt set-up? Thanks
#6448
Hope this workes:
Or else:
Rear Front
Ride Height
5,6m-----5,4mm
Camber
2-----2
Caster
------4
Rear Hub Toe
0------
Toe
2------0
Hex Spacing
Wheel Base
Short-----Short
Steeringlink
------1 - A
Bumpsteer
------2mm
Differentials
Diff-----Spool
Setting
Free, but not slipping
Belt tension number
7-----2
Cam Holder
A-----A
Tires
RP-30-----RP-30
Additive + amount
Tire Tweak 100% 100%
Shocks
30WT-----30WT
Piston
#3-----#3
Rebound
10%------10%
Springs
HPI silver 16,9------HPI silver 16,9
Suspension Geometry
Shock posistion
2-B------2-B
Camberlink
5------5
Outerball en Shimms
A-1mm ------ std
FWD Arm mounts
2-----3
FWD Mount shims
-------0,5mm
RWD Arm mounts
1------2
RWD Mount shims
1.5mm------
Droop
5mm------6mm
Antiroll barr
Thin------ Medium
Battery position:
Forward
#6450
With stock I have the heighest punch mode (6 if i'm correct with the 2007 software).
With modified 1:10 it depends on the track, but normally 3 or 4.
1:12 modified i'm driving puch controle at 1
Dragbrake = always 0
Internal brake = always 0
And always at NIMH mode because we drive 5 cells.
