Team Associated TC5
#2791
Hey Brent have you guys thought about aluminum steering knuckles and aluminum rear hubs for the indoor season.
They seem to be a very very popular items that the other big tc companies are selling.
And the rear hubs would be great to help free up the rear end in higher traction carpet foam tire racing
#2792
Front and rear the same setting?? Is this something new to the belted car. I always ran the rear a little looser than the front.
Thanks for the info. The car is built and the batteries are chargin'.
#2795
#2796
Just remember, once the diff slips once, it's only downhill from there. It's better to start tight and loosen.
#2797
Yea, maybe a bit tighter in the front. A lot of times you can tune the diff action by changing the grease. Try the Associated Silicone Grease (#6636) in the front and the standard Stealth lube in the back.
Instead use the Associated Silicone Grease (#6636)on front diff, can i use the front diff with 1/8 out setting; a bit tighter than the rear(1/4 out), what is better way?
By the way could you post here the setups (power values) of Sphere TC you used on Reedy Race 2007?
Thanks a lot,
Fabian Kaloustian
Brazil
#2798
By the way,
Congrats for all Team Associated crew for AWESOME, results for the TC5
Fabian Kaloustian
Brazil
Team Associated / Reedy / LRP / JACO
Fabian Kaloustian
Brazil
#2800
#2801
Tech Legend
Trader Rating: 51 (100%+)
Inquiry minds want to know if Kevin is bringing out the new TC5 to the Express Race for some beat down. Teach had his out last weekend at 301 so I hope to see another one this weekend.
#2803
Brian,
As tempting as a beating would be this weekend, I am sorry to say I will not be at the Express Race.
The car will hit the carpet at Horsham first. I need to shake the rust off and see what I can do with the car.
Brent,
You need to come out next year for the EXpress Race.
Later
Kevin Boyle
#2805
It will fit, but getting the motor close enough to it for the pinion to touch, I am not sure of. What kind of motor are you running? My guess is that would need a 28 tooth pinion in order to mesh with a 72 spur, again this ia a guess. That would give you a 5.14 ratio which is good for siler can racing and maybe the novak 13.5.
