Mugen MTC2
#1741
#1742
You can drill some stock ones
https://www.amainhobbies.com/j-t-bea...AaAszYEALw_wcB
#1743
#1744
#1745
#1746
Added a few more things to thingiverse:
1 Fuel line cutter.
Remember the upstops, TPU was way too stiff so I went back to silicone fuel lines at the dampers for an upstop. No need to discuss if this works, doesnt work, drives awfully,....
If you want to try it, you can at least decently cut the fuel lines the same and at a set length using this:
https://www.thingiverse.com/thing:6559367
2. Droop measurement circle:
Used this to setup my droop, nice and consistent; measurment to the bottom side of the wheel hex. I found this easier than measuring on the bottom of the arm. This figures should be around the same as the ones used in the setup sheets (for me they are, but theres printer tolerances, car part tolerances,... Use it if you`re interested.
I happen to use blocks of 8mm beneath my chassis, Also made a 10mm version because I know most will have 10mm droop blocks laying around :-)
https://www.thingiverse.com/thing:6559359
Let me know of any improvements I might be able to make.
1 Fuel line cutter.
#1747
1 Fuel line cutter.
1 Fuel line cutter.
#1748
Regional Moderator
Anyone tried cutting to braces on the upper arms? Gave it a try this weekend, cutting all the braces in the front and only the middle brace in the rear, and really transformed the handling characteristics of the car. The car became more lively and more responsive to drive after the cut.
#1749
I bought my MTC2 used and it had the center braces cut on front and rear arms. Haven't tried the car ever with uncut arms but am in the middle of a full rebuild of the car. I have a spare set of arms new in package and thinking about trying it or not....
What do you mean more lively? More grip? Do you race on asphalt or carpet?
#1750
Regional Moderator
This was on asphalt.
#1751
I personally haven't tried it but the people I know who have done it say similar things. They all did it under medium bite. I did try awsomatix style upper arms and the feel so unreal. I haven't felt a car that balance before and no setup changes were done. Im currently in the process on converting mine to be a mugenmatix during my rebuild.
#1752
Back when I ran the MTC2, I ran cut upper arms and agree with what you said. Having more upper arm flex definitely gave the car more grip in my experience, and the car also felt more "free" (on asphalt).
I haven't tried cut upper arms on the MTC2r, as I haven't seen a setup sheet using them. My personal guess is that's because the new car has more flex than the old car did (shorter motor mount, different top deck), especially with the optional split decks that everyone seems to be running. Might be worth a try though after hearing your experience
#1753
Hello would like to know if MTC2R original arms are the hard version because at manual it states normal or they are the same as MTC2 soft arms, thanks
#1754
