Mugen MTC2
#1606
track width isn't affected by grinding the axle studs. Track width is affected by the wheel hexes. the stud can have 2 threads exposed or 20 threads and wheel is still end up on the same location.
#1607
I've done that before and you can make hard to start threading on the nut. the correct way is to chamfer the end of the screw but I really don't feel like taking all that off to grind away at the stud. That just my preference. btw I really only broke that axle because I was riding the barrier and only of the boards stuck it meet with the other one and I would get to catch that edge. In my case, It was my of a fluke and the 2nd axle from t-bone a car that spun infront of me. another scenario where the axle probably shouldn't have not broken
#1609
I know vta and usgt use a different tires and usually require you to space them off so they clear steering plates. but regardless, it sounds like cutting them is a bad idea from a setup standup point as you would be limiting yourself how wide you can make the car.
#1611
Any tips on making sweeps work. In general I struggle with getting tire temp into them. I didn't have much success figuring them out.
#1614
Ive only ran one set of sweep 36 and didn't encounter any binding issues. well at least not that notice. I did recently have a rim bind but I had a bent plate steering plate that I hadn't noticed. other than that stock hexes.
#1615
Touring car body
Looking at the Zoo racing GOAT body. What are everyone’s thoughts on the best body for 25.5 touring car?
#1617
It all comes down to to chassis set-up and track conditions. I don't recommend the GOAT or the Lens body in your on a tight track or your running a High arm setting. Arms being raised past 1.5MM. More downforce in slower classes over works the car. I run a twister if the grip is high and if the grip is low i run a wolverine. also chassis set-up along with what body your running plays a major part. If you have the time post a set-up and lets see what you are running.
#1618
Considering trying the p63. It's not a bad body for stock racing if you have plenty of rear. Also, the redhawk, is probably the most aerodynamic body but the front end is very strong on it as it sacrifices rear downforce for more aero efficiency. When I ran the redhawk. I was a couple mph on the field with a tired 21.5 motor. Only downside, it's hard to attack in high speed turns with the redhawk.
#1619
Sorry if wrong to post it here. Is there any hints if Mugen will launch a new FF car
