BEST TEMP GUN FOR CHECKING MOTOR TEMPS
Hi,
I just wanted to know what everybody out there is using for a good quality Temp gun to check motor and speedo temps.
Thanks in advance, Mike
An inexpensive IR (infrared) thermometer may have problems taking accurate temperatures of shiny or reflective objects. A good IR thermometer will have the ability to make adjustments for the type of surface that is being measured. One simple solution to more accurately take the temp of a shiny metal object is to apply a small piece of black tape to the object and take the temperature at that location. Obviously you would need to apply the tape before the object is heated. Here a link on Fluke's website that discusses using infrared thremometers...
https://www.fluke.com/en-us/learn/bl...ed-thermometer
Personally I use a cheap Duratrax thermometer for racing. However I'm running slower motors with conservative gearing so I don't really need to run fans on my speed controls or motors. Here is a link...
https://www.duratrax.com/accessories.../dtxp3100.html
look up the temperature scale of a 10k (NTC) thermistor. its a resistor that changes resistance to ground as temperature rises. Its also inside the motor. you dont have the problems that ir sensors have (emmisivity). measure the resistance between the ground pin and the thermistor pin on the efra connector on the motor. its typically 10-15 degrees hotter than temperature on the outside of the can. Different colors will change the accuracy of IR temp. the distance from the measurement also needs a compensation factor.
not every motor mfg puts the thermistor in but all the motors I buy do.
if you just really want a good temp gun then you can do 1 of two things. measure something the color of the can at a known temperature and move the gun to the distance that gets the right temperature and write down the amount its off. then always use that error amount and distance. they are usually repeatable just not accurate.
Thanks, Mike
best as in opinion or best as in repeatable or vest as in accurate?
opinion-use the motor thermistor and get better results without spending money
repeatable-I explained how to neutralize the error of each gun by using neutralizing the effects of color.
accurate-I explained how to use distance to find the focal length.
Its not all the opinion or facts but you quoted me and I didnt name a gun but i did name methods to make guns equal.
Personally I use the motor thermistor or a flir ax8. if I need a quick and dirty measurement I us the HBRFRT centron but I use all of them for something different and none of them are perfect.
Flir and Fluke make most of the best handheld instruments but I wouldnt spend the money because of the ROI. Im not avoiding your question or anyone else’s opinion or even facts,to me a tool is a tool and for what we are doing most of the time a cheap gun is fine. You can make a cheap gun better or you can use something very cheap that is better. its not easy to answer what is the best unless you define what you are doing. That’s ok, allot of people havent considered what kind of problem they need to solve and how to work around them so I elaborated. all guns will be effected to a greater or lesser degree to what I mentioned.
If you are looking for experiences then im sure more people can share with you. Im not the guy to poopoo someone’s experience or claim temp gun master status.
Interesting thought about calibrating for distance. I’m actually a trained Flir user (15 years ago) but we used the technology for simply finding heat sources in the dark. Distance never effected our readings, but we weren’t concerned about specific temps either. We just fought about whether white or black should be “hot” on the monitor
. Anyways I just bought a new stove and picked up a calibrated gauge to confirm the oven calibration. Once I’ve done that I’ll toss in one of my Icon motors, bring it to a calibrated temp and measure with my gun to find the distance. Just one more reason for the wife to think I’m nuts.
. Anyways I just bought a new stove and picked up a calibrated gauge to confirm the oven calibration. Once I’ve done that I’ll toss in one of my Icon motors, bring it to a calibrated temp and measure with my gun to find the distance. Just one more reason for the wife to think I’m nuts.honestly a couple of degrees of error is no big deal in my book. And a good relative temperature is all you need for measureing temp across the width of a tire.
I rely on the datalogger on the tekin esc' the hobby wing only gives you a max number. Nothing in between.
With tekin, you can view the entire story of your run. And then you can export the recorded data log to csv to find rpm averages, and create charts and graphs where it looks like dyno data. There is no esc currently that matches tekin and the features..
Clearly https://www.skyrc.com/Infrared_Thermometer
Because "The infrared emissivity coefficient can be adjusted"
but it begs the question of how many people would use it. I would.
I think you have the same problem I had. only come motor manufacturers include a thermistor in the motor. without it you dont get motor temperature. you can add one and a 10k ntc themistor is very cheap (less than a buck I believe). the monster and xfactor has the thermistors. the reedy s plus does not.
4Likes
