New Tamiya Chassis TC-01 >
Like Tree680Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 05-09-2020, 08:24 PM
  #181
Those should be JIS screws, so a matching set of drivers is needed. Or grinding needs to.be done on Philip driver to makd it work with these screws. Most people just replace them with hex screws. Actually, with Tamiya's tool set, JIS screws arent that bad to use. It is quirky thing alongside Tamiya' s refusal of admitting lipo exists and use of mertic modulegeat instead of standard module for gears.
zxcvb1t is offline
Old 05-09-2020, 10:40 PM
  #182
Speed Chaser's Avatar
It live in Japanese talking about it
Showing parts tree
It also fits Tamiya Toyota Gazoo Racing TS050 Hybrid body
Speed Chaser is offline
Old 05-09-2020, 11:10 PM
  #183
tommy911t's Avatar
Trader Rating: 50 (100%+)
Ah yes, jis. Thanks.
had a few rm01 cars with 380 motors and they were set up for life batts.
I heart tamiya!
tommy911t is offline
Old 05-09-2020, 11:23 PM
  #184
gigaplex's Avatar
You wouldn't happen to be from the USA by any chance? I'll never understand why they insist on being pretty much the only country in the world (well, there's Liberia and Myanmar too) that refuses to use the much more practical metric system.
gigaplex is offline
Old 05-10-2020, 04:22 AM
  #185
sosidge's Avatar
Originally Posted by gigaplex View Post
I take it you haven't seen the M07 chassis have issues with the TCS control motor, it requires modifying the connectors to fit around the chassis brace.
But that's because the TCS is the North American series and they haven't gone with an actual Tamiya motor. Nor do they run actual Tamiya tyres in mini class.
sosidge is offline
Old 05-10-2020, 04:26 AM
  #186
sosidge's Avatar
JIS is hardly quirky. "Japanese Industrial Standard". But their insistence on buiding their cars to suit their own range of LiFe batteries is very frustrating. I've just been tearing my hair out trying to get a Lunchbox Mini to run when you don't have cost-effective access to Tamiya's own electronics and batteries.
sosidge is offline
Old 05-10-2020, 06:03 AM
  #187
I hated that TA05 M-FOUR was built with Tamiya LiFe battery in mind.
Old 05-10-2020, 06:36 AM
  #188
Billy Kelly's Avatar
Wait. A Lipo might not fit in this? Why would Tamiya
Billy Kelly is offline
Old 05-10-2020, 06:39 AM
  #189
A lipo fits in it just fine even the square(assuming from the very flat part of the battery compartment) ones it was shown in the video
Billy Kelly likes this.
Old 05-10-2020, 07:02 AM
  #190
I was just looking at the pictures. I’d seen a early post about Tamiya and Lipo. I watched a little of the video. Not much for reading sub titles in videos
Old 05-10-2020, 02:59 PM
  #191
OSherman's Avatar
Uhmm, how can we just breeze over the fact that the lower bulkheads are molded into the chassis?!? Similar to the M07
i wonder what they learned..
OSherman is offline
Old 05-10-2020, 03:12 PM
  #192
I would modify the mini Lunchbox to work with a 2S Super Shorty battery.
waitwhat is offline
Old 05-11-2020, 01:42 AM
  #193
And upper bulkhead is molded into top plate.. Tamiya did lot of cost cutting on this chassis.
Papi is offline
Old 05-14-2020, 01:10 PM
  #194
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default msrp is up for USA
Tamiya USA msrp: $379.00
Phat-Boy is offline
Old 05-14-2020, 01:31 PM
  #195
That’s too much. Still months away.
